Hi
when I try to copy some data fron CD, I get error 'data error cycle redundancy check' and copying abort. can anybody tell me what can be the solution, there arent any scratches on CD.
u cant correct that error in that cd.the error occurred when that cd was burned.
does the same happened for other CD disc also?
if it doesn't then that disc is gone.
if it does, try cleaning the lens using lens cleaner or disk drive is failing
