Old 23-04-2008, 11:11 AM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Suggestion 4 IDE or SATA hdd ! ! !
yesterday my frd asked me this ? & i was just thinking, scraching my head .... bt needed the right ans ....
he owns a p3 machine with 80gb hdd [ide] ....
now he wants 2 add a new hdd bt is confused abt IDE \ SATA, which 1 2 buy .... as SATA is not supported by his mb bt can b converted 2 external 1 & useful 4 FUTURE [if he upgrades his pc] .....
IDE hdd will b useful now bt in future he will have 2 buy an external casing 4 this only ......
whot do u think, which 2 buy ?
... W H O T ...
ax3 is offline
Old 23-04-2008, 11:39 PM   #2 (permalink)
aswin1's Avatar
Default Re: Suggestion 4 IDE or SATA hdd ! ! !
If he can use SATA adapter then he should go for SATA anyday.
aswin1 is offline
Old 24-04-2008, 05:24 PM   #3 (permalink)
ax3
ax3's Avatar
bt have heard abt many SATA drives being faulty, HERE ......
is SATA adapter = sata external drive kit ......
... W H O T ...
ax3 is offline
Old 24-04-2008, 08:10 PM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
I would recommend a IDE HDD for now.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 26-04-2008, 12:45 PM   #5 (permalink)
ax3
ax3's Avatar
is hdd [ide\sata] more dangerous\@risk with external kit ?
... W H O T ...
ax3 is offline
Old 27-04-2008, 07:54 PM   #6 (permalink)
Fast 'N' Furious
topgear's Avatar
Purchase a good quality casing and handle the case carefully - all dangers will be gone
topgear is offline
Old 28-04-2008, 04:27 PM   #7 (permalink)
ax3
ax3's Avatar
yup .... will follow ur +vise ..... bt now SATA external kits r expensive compared 2 IDE 1`s .....
IDE = 300 rs
SATA = 900 rs
... W H O T ...
ax3 is offline
Old 30-04-2008, 08:40 PM   #8 (permalink)
Fast 'N' Furious
topgear's Avatar
But i've suggested ide external kitwith usb pal
topgear is offline
Old 01-05-2008, 11:45 AM   #9 (permalink)
ax3
ax3's Avatar
@topgear .... yes yes .... i was just comparing both kits in price ....
any pros \ cons of IDE | SATA ?
... W H O T ...
ax3 is offline
Old 01-05-2008, 08:11 PM   #10 (permalink)
Fast 'N' Furious
topgear's Avatar
Cool Re: Suggestion 4 IDE or SATA hdd ! ! !
That's Ok pal.
I think ( not sure ) IDE/SATA external casings are same ( performance wise ) as they depends on your HDD speed & external casings & mobos usb interface speed
topgear is offline
Old 02-05-2008, 12:28 PM   #11 (permalink)
ax3
ax3's Avatar
ohh .... thanx bt any pros \ cons of IDE | SATA HDD ? ....
sorry 4got 2 add hdd ..... cos new sata is cheap while ide is costly .....
... W H O T ...
ax3 is offline
Old 02-05-2008, 01:19 PM   #12 (permalink)
Bond, Desi Bond!
desiibond's Avatar
His system doesnt' support SATA then what is the need for searching for SATA converters etc. Use IDE and stay safe.
desiibond is offline
Old 02-05-2008, 04:18 PM   #13 (permalink)
ax3
ax3's Avatar
hey bond .... just thinking abt the FUTURE ..... saving money .....
ide hdd wont b of any use lateron ..... as SATA`s r new & supported on new mb`s .......
... W H O T ...
ax3 is offline
SATA ROCKS : Fujitsu intros first 2.5" 7200 rpm hard drive with SATA 2.5 interface techtronic Technology News 7 22-03-2009 11:09 PM
Sata-II hard disk working at Sata-I mode Arsenal_Gunners Hardware Q&A 27 17-03-2009 10:18 PM
Install windows on a sata HDD connected through IDE to SATA converter bhunnu16 Hardware Q&A 3 10-01-2008 04:22 PM
Sata + IDE = Will it work? + DVD RW suggestion. cooldip10 QnA (read only) 8 11-05-2007 12:54 AM
Can I attach a new sata drive to my existing Seagate 80GB SATA HDD? praka123 Hardware Q&A 6 04-02-2007 06:28 PM
- by c4u
