Old 22-04-2008, 05:29 AM   #1 (permalink)
jatt's Avatar
Exclamation Suggest me for mem upgrade
I have HP compaq presario V2000 with 256MB RAM i want to install windows vista on it.so i need to upgrade its RAM.please suggest here for upgardes.
thanks in advance.
ਨੋ ਗਰਲ ਫਰੈਂਡ ਨੋ ਟੈਂਨਸ਼ਨ,no girlfriend no tension,website: Punjabi.c-o.in,forum: punjabiteacher.co.cc
jatt is offline
Old 22-04-2008, 05:39 PM   #2 (permalink)
Default Re: Suggest me for mem upgrade
contact HP
consult HP offical sites.
i think for laptop you can upgrade the memory yourself..graphics not possible...processor not possible if possible to be done by company
realdan is offline
Old 23-04-2008, 10:33 AM   #3 (permalink)
jatt's Avatar
Originally Posted by realdan View Post
contact HP
thanks friend for ans. but please suggest me about memory upgrade currently i m using 256MB,i want to upgrade it can i need to go 2GB or 512MB.
which will suitable for my laptop.
jatt is offline
Old 23-04-2008, 10:40 AM   #4 (permalink)
gopz's Avatar
It wil be waste of money and efforts to install Vista, because it will be slow on your laptop. Better upgrade the laptop first or stick to Win XP. Even if you upgrade the RAM to 2GB, I doubt if Vista will run smooth.
gopz is offline
Old 23-04-2008, 01:59 PM   #5 (permalink)
running windows xp 1gb (even upgrading to 512mb you will notice performance boost)..vista without eye candy 2gb will manage but wont perform as well as if it is xp...i think the reason u asked for upgrade is becos you dont wanted to spend that much on buying a new system, is it?
realdan is offline
Old 24-04-2008, 02:17 PM   #6 (permalink)
jatt's Avatar
first of all thanks to you frnds for answer.yes you guessed,i don't want to spend much money on system.
please suggest memory which company and also cost in delhi please.
thanks in advance.
jatt is offline
Old 24-04-2008, 03:10 PM   #7 (permalink)
i think it is better that you head to www.crucial.com
and use the crucial system scanner tool to determine what type of memory is supported by your system. This will ensure that you won't be suggested the wrong memory type for your particular model of that series of laptop by compaq.
after determining the exact memory type, you could then take a look at the same memory from other brands like kingston, corsair, transcend
realdan is offline
Old 24-04-2008, 04:18 PM   #8 (permalink)
jatt's Avatar
@realdan thanks very very much to give me correct suggestion. my second question please help me
i have 2 slots on my system(one have 256MB and one is blank) but system not support dual channle memory.but i confused,do i need to purchase another one 256MB ram to make total 512MB or my system will not support for another adding 256MB(as it has not dual channle support)
please suggest me here so that i can come out from this confusion.
help me frnds
jatt is offline
Old 25-04-2008, 06:43 AM   #9 (permalink)
jatt's Avatar
please anybody give reply here for my questions
jatt is offline
Old 25-04-2008, 08:36 AM   #10 (permalink)
dOm1naTOr's Avatar
Better get another 512MB or 1G stick as dual channel 512 is not helpful for Vista. Even in XP most of the time 1G single channel seems better than 512 dual channel as the memory usage in XP w/o ny apps running wud come close to 300~400, so not much room for apps.
And dun even try vista on 512.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 25-04-2008, 12:03 PM   #11 (permalink)
jatt's Avatar
thanx frnds for help me here.
jatt is offline
suggest upgrade INS-ANI QnA (read only) 1 19-04-2008 06:29 PM
Suggest an upgrade hitman050 Hardware Q&A 8 27-02-2007 09:21 AM
suggest a solution for this pc upgrade techdoc Hardware Q&A 5 06-10-2006 10:49 PM
AMD system upgrade..err??no u all bored of upgrade forums but pls do help me...!! karthik316_1999 Internet & WWW 11 18-07-2006 08:10 PM
Plz Suggest upgrade for budget. Tommy Vercetti Hardware Q&A 4 06-12-2005 02:58 PM
- by c4u
