Old 21-04-2008, 08:22 PM   #1 (permalink)
Yoda's Avatar
Default Benq DVD-Writer Problem. Not accepting any Media. Please Help
Hi Friends
I've a Benq DVD-Writer (BenQ DW1640). For the past few weeks the Benq DVD-Writer is not taking in any disc.
If I insert a Media the Benq DVD Drive it just simply ejects it. It doesn't take any media. CD-R, CD-RW, DVD-R, DVD-RW. I don't know why. I see the DVD-Writer in the Windows Explorer and in Device Manager.
My another Lite-On LH-20A1S (DVD Writer) (SATA) is working fine.
OS: Windows XP (SP2)
Please help me solve this issue. Thanks a lot
Regards
Yoda
Yoda is offline
Old 22-04-2008, 12:12 AM   #2 (permalink)
At Hell's Disq
hellgate's Avatar
Default Re: Benq DVD-Writer Problem. Not accepting any Media. Please Help
if the writer is in warranty then get it replaced.
else clean the lens 1st,if prob is stil there the update the firmware.
hellgate is offline
Old 22-04-2008, 07:07 AM   #3 (permalink)
Yoda's Avatar
thanks a lot for the reply hellgate and will try the methods to repair it
Yoda is offline
Old 22-04-2008, 04:53 PM   #4 (permalink)
i think the drive is suffering from optical media form of anorexia..symptoms of imminent failure
realdan is offline
BenQ 1650 or BenQ 1670 Chirag Hardware Q&A 6 17-11-2006 12:51 PM
benq dvd writer hsnayvid QnA (read only) 2 05-04-2006 10:27 PM
Why Benq 1640 DVD Writer is so popular? Vishal Gupta QnA (read only) 4 25-08-2005 10:32 AM
Benq writer vasanth_12345 QnA (read only) 7 06-03-2005 03:38 PM
- by c4u
