Old 21-04-2008, 03:50 PM   #1 (permalink)
Exclamation What A Problem?
I have been handling a server from last 2 months.Actually this server as owner says got restart suddenly then when it started working suddenly all machine attached to it got dump error.After manually restarting the server the attached machine came back to life but server got out off order.Its getting restart continuously after every 10 seconds.It reaches till booting point then suddenly dump error screen flashes for a second or two then again it gets restart.
I am trying to solve this problem but am not getting where it is actually.So now I have decided to format its C drive,but problem is that office persons will loose there database as they didnt took backup from last week.
What to do?
rtginc is offline
Old 21-04-2008, 03:53 PM   #2 (permalink)
Default Re: What A Problem?
Your problem seems to be critical but it seems to me that you don't have any other option than to tell office persons to loose database of a week but this data can be restored by restoring softwares available.
marketraise is offline
Old 22-04-2008, 05:47 PM   #3 (permalink)
i think you should get a more qualified personnel to solve the issues with the server itself. from what i see, you can't start the server? but what database is it running? what server version? you can backup the database actually how? first one need to know what database is it running
are u hired to repair/recover the server? or you are the server administrator?
realdan is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
- by c4u
