Old 21-04-2008, 11:58 AM   #1 (permalink)
Fullbring
Zangetsu's Avatar
Question SMPS Watts
Is there any tool/software using which I can figure out the watt of my
SMPS/PSU ? :think:
coz I couldnt figure how much watt is my PSU is...
Zangetsu is offline
Old 21-04-2008, 01:58 PM   #2 (permalink)
4Ghz Here I come !
Demonkiller's Avatar
Default Re: SMPS Watts
Is there any sticker on ur PSU?
e6750 Lapped(3.2Ghz Constant),AC7,P5N-e SLI,XMS2 1066 2x1+G.Skill PK's 2x1Gb,Ultra X2 750W,EVGA 8800GT SC+Galaxy 8800GT SLI
e4300@3.5 http://valid.x86-secret.com/show_oc.php?id=310431
Demonkiller is offline
Old 21-04-2008, 02:55 PM   #3 (permalink)
Fullbring
Zangetsu's Avatar
nope....no sticker...& I've not opened my PSU yet....
Zangetsu is offline
Old 21-04-2008, 03:02 PM   #4 (permalink)
rameeze's Avatar
I think there is no software or program to check the wattage of smps, because smps only provide power to system and there is no sensor or data cable is connected to smps.
rameeze is offline
Old 21-04-2008, 03:11 PM   #5 (permalink)
Fullbring
Zangetsu's Avatar
fine...then how do i know my psu watts...
Zangetsu is offline
Old 22-04-2008, 06:29 PM   #6 (permalink)
SMPS Watts
realdan is offline
Old 22-04-2008, 11:00 PM   #7 (permalink)
dOm1naTOr's Avatar
U dun have to open ur PSU to find out the rating. Just open the cabby, nd look for a sticker on its body cover. For some local PSUs the sticker can be on either side or even beneath or top of it.
There isnt ny other way. Or ask ur shopkeeper-what PSU did he bundled with ur cabby?
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
SMPS Watts Zangetsu Hardware Q&A 3 22-04-2008 05:03 PM
Intel’s new 3.0 GHz quad 45nm QX9650 uses less than 65 watts Gigacore Technology News 12 31-10-2007 07:00 PM
Zebronics 500W SMPS. Is it a good SMPS. Advice needed. Yoda QnA (read only) 4 13-11-2004 11:15 PM
PowerSafe 400 Watts SMPS vs. VIP 450-Watts SATA Power Supply shyamthakkar QnA (read only) 2 28-10-2004 07:35 PM
- by c4u
