Old 20-04-2008, 06:39 PM   #1 (permalink)
a_k_s_h_a_y's Avatar
Smile life expectany of a laptop
how man years can you expect a laptop to function properly !
especially the LCD
can i expect a dell 1525 to work without problems for 4 years ?
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
a_k_s_h_a_y is online now
Old 20-04-2008, 06:49 PM   #2 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: life expectany of a laptop
My Acer 5002 NWLMI came for two without any problems. Battery was good too, I could use it for an hour without charging (two hours at the time of purchase). I sold it to a student of mine, he spoilt the battery in two months by always keeping it on charge and using it as a desktop :S
The LCD screen had a small artefact in top right corner at the time I sold it to him. It was like a shadow and was only visible when viewing at an angle. NO DEAD PIXELS
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 20-04-2008, 09:11 PM   #3 (permalink)
Another Brick in the Wall
drgrudge's Avatar
The main concern is the battery and not LCD. I had used a Dell 6400. In the beginning it used to come for 2.5 hours and after 7-8 months usage (didn't use as a desktop) the battery lasted 1 hr 45 min - 2 hr. Trackpad gets 'smooth' and the keys gets 'loose'. Now using a MacBook Pro (as a desktop) for 6 months and till now no issues.
Battery issues apart, I feel you can use your lappy for 2 years.
drgrudge is offline
Old 20-04-2008, 09:26 PM   #4 (permalink)
dOm1naTOr's Avatar
Can we use local batteries with Dell lappys?
And which yields better battery life? frequent charging, continuous charging( using like a desktop), or charging only when batter life is low?
And tips bout lappy charging?
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 20-04-2008, 09:39 PM   #5 (permalink)
TheSaint
Local? Exide or Amaron? No
Just kidding, you do get generic batteries abroad, don't know about here in India. They usually specify for which laptop it can be used.
It's like a cell phone, Lithium ion, don't charge all day. I charged for 12 hours first time, and there after six hours each time. I used to use the battery till it asks me to plug in the power supply, and then charge it non-stop for six hours.
Old 20-04-2008, 09:48 PM   #6 (permalink)
dOm1naTOr's Avatar
Ive been using a SE phone which uses a Ly-Pol battery. It prefers frequent charing and that way once fully charged, gives very gud backup.
Is there ny other way by which we can use it as a desktop w/o damaging the battery?
G3: XPS M1530 |
FZ 16.
Old 20-04-2008, 09:50 PM   #7 (permalink)
Elevating Humanity
The Conqueror's Avatar
your laptop can run forever provided u use it properly and are not intersted in latest tech jokes apart, i think 3-4 years should be enough
Regards,
The Conqueror
The Conqueror is online now
Old 20-04-2008, 09:58 PM   #8 (permalink)
TheSaint
Many laptops will work without the battery plugged in. Try and see. Depends on the laptop, if the battery is a part of the power circuit then it won't work. If you have the battery in place then you have to keep discharging/recharging it.
Read this
http://mobileoffice.about.com/od/usi...topbattmtc.htm
Old 20-04-2008, 10:49 PM   #9 (permalink)
dOm1naTOr's Avatar
thnx
G3: XPS M1530 |
FZ 16.
Old 20-04-2008, 10:51 PM   #10 (permalink)
drgrudge's Avatar
My lappy comes for 4 hours (4.5 hrs without HDD activity) and using for over 6 months like a desktop. Anyways battery damage is inevitable. But with some effort and care you can prolong it's life.
Here some tips which helps:
1. Never keep charging your lappy. When it's fully charged, remove from the AC power.
2. Also never let your battery to drain fully and shut/sleep automatically.
3. When you don't need Wifi and BT, switch it off.
4. Reduce the brightness of the LCD. Keep at bare minimum where you're comfortable.
5. Don't install programs you don't use. Apps which use less system resource also helps.
6. Turn the display off when you don't need to 'see' like when playing music or downloading.
7. Remove external devices (like USB mouse, External HDD) if you don't need it.
drgrudge is offline
Old 20-04-2008, 11:15 PM   #11 (permalink)
cool.
i wanted a laptop to last 4 years. will be mostly using on power connection for 1st 2 years
next 2 years the battery usage start
will this work out ?
drd thanks for tips. shall use them for my SE phone now. i let my phone stop and shut completely before recharging
kind of sucks if dell works only when battery is plugged in as nkore says. i would like to remove it ans use on AC power as a desktop
Old 20-04-2008, 11:53 PM   #12 (permalink)
I M A *STAR*
saqib_khan's Avatar
nowadays, u can't tell human life expectancy & u all r talking abt laptop's life expectancy!!!!!!
Nice topic "life expectany of a laptop"
Blogging at:
Technostarry
saqib_khan is offline
Old 20-04-2008, 11:56 PM   #13 (permalink)
dOm1naTOr's Avatar
Hi, ive ordered a Dell XPS M1530 lappy
It has a C2D, 4G ram, and 8600M GT. And the provided charger is a 90W. Will it be able to run the lappy w/o battery?
Coz i think the lappy itself will consume more power than 90w at load.
And moreover, Dell Inspiron comes with 65W charger. How cud it run on charger itself as the proccy nd gcard itself draws more power than that?
@khansaqib101
there do exist an avg life span for most living beings including humans which is some 60~70. Its due to their own fault(or some other's) that they break the neck very early
Hope lappys dun get same fate
G3: XPS M1530 |
FZ 16.
Old 20-04-2008, 11:59 PM   #14 (permalink)
drgrudge's Avatar
I think it should run. My Dell Inspiron 6400 could run without battery.
drgrudge is offline
Locate Laptop - locates your stolen laptop! parthbarot Technology News 11 16-03-2008 11:29 AM
Half Life 1 on laptop. harpoon Gamerz 6 03-11-2007 11:43 PM
Intel and PowerTOP extend Linux laptop battery life praka123 Technology News 5 19-05-2007 11:20 AM
Laptop Lan Config error work only with laptop not with pc minniawochat PC Components / Configurations 4 19-09-2006 03:21 PM
- by c4u
