Old 18-04-2008, 04:20 PM   #1 (permalink)
Default How i Check SMPS Working????
Hi Friends,
How i can check my smps ins working or not without using computer.
sagar_1star is offline
Old 18-04-2008, 08:05 PM   #2 (permalink)
JAK
What the Heck !
JAK's Avatar
Default Re: How i Check SMPS Working????
Originally Posted by sagar_1star View Post
Hi Friends,
Power up the smps and short the green wire with any black wire(use a extra piece of wire or use scissors)....
Risk more than what others think is safe.
Care more than what others think is caring.
Think more than what others think is thoughtful.
Do more than what others think is possible.
JAK is offline
Old 21-04-2008, 11:11 AM   #3 (permalink)
Except Shorting wire Any more Idea.?
Old 21-04-2008, 01:25 PM   #4 (permalink)
I M A *STAR*
saqib_khan's Avatar
Do what JAK has said.
It's correct.
Blogging at:
Technostarry
saqib_khan is offline
How to check if my mother board is working or not? ajayritik Hardware Q&A 2 29-08-2007 07:54 PM
java Script help, Drop down and check box not working. bukaida QnA (read only) 3 14-09-2006 01:55 PM
SMPS Voltage drop stops AGP from working? midhunmon QnA (read only) 3 23-08-2006 03:10 AM
HOw to Dertemine that SMps is Working fine or not?? gary4gar QnA (read only) 6 30-05-2006 07:35 PM
Zebronics 500W SMPS. Is it a good SMPS. Advice needed. Yoda QnA (read only) 4 13-11-2004 11:15 PM
- by c4u
