Old 17-04-2008, 03:45 PM   #1 (permalink)
Default Different frequency DIMM on GA 945GZM S2
Greetings..,
i am wondering is it possible to use two 1 GB DIMM of 533 MHz and 667 MHz DDR2,
on motherboard GA-945GZM-S2 with
intel C2D 4500 processor.
courser is offline
Old 18-04-2008, 12:15 AM   #2 (permalink)
pratik03's Avatar
Default Re: Different frequency DIMM on GA 945GZM S2
Yes you can use two DDR2 Ram having different frequencies but your higher freq ram will run at freq of slower ram.
In your case ddr2 667mhz ram will run at 533mhz.
pratik03 is offline
Old 24-04-2008, 11:45 PM   #3 (permalink)
The Revolutionary
thetillian's Avatar
Works fine but no dual channel there is loss in spped
thetillian is offline
Old 25-04-2008, 01:47 AM   #4 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Both modules will run at 533MHz and in dual channel with no problem. But it is always advisable to match the sticks.
john_the_ultimate is offline
Transcend Releases 2GB DDR2-800 ECC Unbuffered DIMM Gigacore Technology News 10 17-09-2007 12:02 AM
945gzm s2 compatible graphics card courser Graphic cards 2 15-09-2007 09:09 AM
Out of Frequency linardni QnA (read only) 1 01-08-2007 02:44 AM
RAM frequency..... shyamno Hardware Q&A 5 26-11-2006 12:02 PM
- by c4u
