Old 17-04-2008, 03:34 PM   #1 (permalink)
rameeze's Avatar
Default PC is working slow
PC is working slow , I have done disk cleanup, deleted temperary files and defragmented all drives. there is no virus detected still it is slow.pls help
rameeze is offline
Old 17-04-2008, 03:55 PM   #2 (permalink)
Linux Learner
PcEnthu's Avatar
Default Re: PC is working slow
IIRC U r having an ancient system with a 700 Mhz proccy and low RAM.
1. Consider upgrading the system or atleast increase the amount of RAM.
(or)
1. Have adequate empty space in the root drive, so that the windows page file will be handled easily
2. Disable some visual effects
3. Disable some windows services that u don't use, like the 'Auto update', 'System restore', 'Remote assitance'
P.S: Why have u posted the same thread in two sections?
Its better ti keep your mouth shut and be thought as a fool, than to open and clear all doubts - [Source] Comments section of DistroWatch.Com
PcEnthu is offline
Old 17-04-2008, 03:59 PM   #3 (permalink)
rameeze's Avatar
(or)
because i dont know it is s/w problem orh/w
its 512 ram and 3 ghz P IV processor
rameeze is offline
Old 17-04-2008, 04:10 PM   #4 (permalink)
www.system86.blogspot.com
devilinearth's Avatar
it must be some software problem....delete all the unwanted applications from startup...try cleaning your registry...
give proper cooling to your pc...is there any heating problem with your processor...
is your graphics driver properly installed???
devilinearth is offline
Old 17-04-2008, 04:14 PM   #5 (permalink)
rameeze's Avatar
there is no heating problem And graphic driver is also installed properly
rameeze is offline
Old 17-04-2008, 05:39 PM   #6 (permalink)
try this simple trick. create a new user profile from the user accounts option in control panel. boot into the new profile and then delete the old profile which u were using from advanced setting found in 'my computer' i think.
this gives u a (partly) new registry and things maybe faster. it worked for me.... if not, then format it and reinstall windows
kooki is offline
internet not working on vista but working on xp kanz Software Q&A 4 15-04-2008 05:28 PM
Keyboard Working Slow? paragkalra Hardware Q&A 1 02-11-2006 08:43 AM
** Working/Not-Working Programs with VISTA ** PrinceHeart Software Q&A 42 01-10-2006 04:01 PM
computer is working very slow & unstable ajeet_00 Software Q&A 7 06-01-2006 11:15 PM
Slow XP---Help me! nithinks Software Q&A 8 16-06-2005 12:20 AM
- by c4u
