Old 17-04-2008, 10:58 AM   #1 (permalink)
www.system86.blogspot.com
devilinearth's Avatar
Smile Laptop Screen Flickering...Help Needed
Hi All...i need some help...
Last month i bought an Acer Laptop...its Acer Aspire 4720...linux was the os in it..so i told the computer shop guy to load windows xp in it...he does...now the problem is that...the screen flickers at low brightness...the screen only luks gud at maximum brightness...i used to keep th brightness to minimum to save battery..but the screen is flickering at that setting...its a bit annoying...
i have installed all the drivers correctly...i got a resource dvd with my laptop..it contains all the drivers for windows xp and windows vista.....
i dont know whts the problem....???
my friend is havin the same laptop..but he is using windows vista...he is not having any problem....
my configuration is
core2duo 1.5,intel 965 graphics,160gb hdd,1gb ram
pls help me.....thanx in advance
devilinearth is offline
Old 17-04-2008, 12:25 PM   #2 (permalink)
rameeze's Avatar
Default Re: Laptop Screen Flickering...Help Needed
I think there is fault with battery. exchange the battery with your friends laptop and see.
rameeze is offline
Old 17-04-2008, 12:55 PM   #3 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
instead of trying things out urself JUST RUN 2 ur nearest acer shop from where u purchased it ....
... W H O T ...
ax3 is offline
Old 17-04-2008, 02:47 PM   #4 (permalink)
maybe you could fiddle with the refresh rate also n try your luck..
dragonlord is offline
Old 17-04-2008, 04:06 PM   #5 (permalink)
i tried changing the battery....no use...i cant change the refresh rate...its struk with 60 hz....
i'm stayin in a hostel....there r no computer shops nearby...so i hav to wait till my vacations....
the battery is not the problem...coz the screen doesnt flickers at maximum brightness....i reinstalled win xp and all the drivers...still no use...
or is there any other way to fix it?????
shal i install vista????
Old 18-04-2008, 05:48 PM   #6 (permalink)
nobody to help me????
cleaning laptop (LCD) screen Sridhar_Rao Laptops and Netbooks 2 01-03-2007 07:06 PM
Can I change laptop screen resolution repeatedly? tech_lover Hardware Q&A 2 22-10-2006 01:36 PM
of 6600 & Laptop Screen pickster Laptops and Netbooks 14 21-03-2006 09:21 AM
My PC screen is flickering sush5 QnA (read only) 6 20-09-2005 10:16 AM
- by c4u
