Most prob it will be bcos of bad media. Try another DVD/another brand DVD. If u r getting this error with many brand DVDs, ur writer wud have gone bad.
but it still burns properly with the same brand media and sometimes it refuses ...
i think if im not wrong power calibration means the drive tried to burn a little bit of information on the disk before it actually started burning for watever reason..if it cant read what it has burn then it will return the error...i m afraid it is a failing writer...its dvd lens have weaken to a point where it could no longer muster enough fire power to burn a dvd..as a last resort you could try cleaning it with a DVD lens cleaner...yes CD lens i think are separate from DVD one .can it burn CD?
looks like nowadays there are no good optical drives..im thinking of buying one but have bad experience with both sony and liteon and no samsung or lg for me...i lost belief in brands of these giants
Most common reason is bad media.. Make sure u arent using cheap quality media such as umax nd all... i wud suggest moserbaer.. or else you can also try burning at low speeds..
