Old 15-04-2008, 11:31 PM   #1 (permalink)
Traceur
zegulas's Avatar
Default Seagate ST 3250310AS problem.
I just bought it, its 250 GB SATA drive, I also have 80 GB PATA(which has winXP installed in it), now I have connected it, but isnt showing up in My computer nor in Disk Managment!
And it also shows drivers not installed.
Parkour: A journey started by two & followed by many...
zegulas is offline
Old 15-04-2008, 11:50 PM   #2 (permalink)
GaurishSharma.com
gary4gar's Avatar
Default Re: Seagate ST 3250310AS problem.
Check, if it is detected in BIOS.
else, check for loose connection in data & power cables
gary4gar is offline
Old 16-04-2008, 01:17 AM   #3 (permalink)
Traceur
zegulas's Avatar
In BIOS does it show like BSS or something like tat?? then yes its detected.
zegulas is offline
Old 16-04-2008, 12:46 PM   #4 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
is ur mb supporting it .... if yes, then load its updated drivers from its site .....
... W H O T ...
ax3 is offline
Old 17-04-2008, 10:46 PM   #5 (permalink)
Traceur
zegulas's Avatar
Actually its detected in Windows XP, but it shows "new hardware found". But is unable to install required drivers.
So thats why its not working.
zegulas is offline
Old 17-04-2008, 11:08 PM   #6 (permalink)
Traceur
zegulas's Avatar
This is what it shows in device manager.
zegulas is offline
Old 18-04-2008, 11:33 AM   #7 (permalink)
ax3
ax3's Avatar
u need 2 install raid drivers ..... it will work after that .....
... W H O T ...
ax3 is offline
Old 18-04-2008, 12:00 PM   #8 (permalink)
Traceur
zegulas's Avatar
Could you please tell me where to get them?
zegulas is offline
Old 22-04-2008, 04:13 PM   #9 (permalink)
ax3
ax3's Avatar
from ur motherboard website .....
... W H O T ...
ax3 is offline
Old 22-04-2008, 04:36 PM   #10 (permalink)
it is strange that raid controller has an error question mark over it in device manager..since you are not running in raid in the first place. right click on it and select uninstall. Then, follow what is below in the next para.
since sata hdd can be connected to your mb, it is supported and your mb cd will definitely have drive controller related to it somewhere. just pop in the cd and install the relevant controller for your type of drive.
access to a second PC or friends' PC will enable you check out whether the sata hdd to be in working condition or not.
realdan is offline
seagate hardisk problem jatt Hardware Q&A 4 07-06-2007 10:51 PM
Problem with Seagate 200GB SATA stalin Software Q&A 6 28-02-2007 02:10 PM
Partioning Problem Seagate 250 Sata gaju6696 QnA (read only) 2 02-07-2006 09:23 PM
problem with seagate hd runtime error QnA (read only) 3 09-09-2005 12:18 AM
Problem with Seagate Barracuda Aleena QnA (read only) 3 15-10-2004 04:43 PM
- by c4u
