I have an
IOGEAR 160gb external hard drive,USB powered,which i dropped by mistake and since then its not getting detected...
When i connect it to the comp i get the beep once but the drives never show up...i can even
feel the disk rotating in the hard drive when i hold it in my hand..have tried using it in other PC's too but no help...and yes the led light on the case does come ON as well..
I then opened up the case to see if there were any loose connections or crack on the hard drive but nothing to be found...the circuit board and the hard drive looked normal...and for the info. its an
Western Digital hard drive in the case...
Now please help me with it..the hard was almost full hence there is lot of data in it and i need to recover it...what do i do with it now?
