Old 15-04-2008, 01:00 PM   #1 (permalink)
rameeze's Avatar
Default automaticaly restarts
pc restarts automaticaly what could be problem
rameeze is offline
Old 15-04-2008, 01:10 PM   #2 (permalink)
Default Re: automaticaly restarts
err
you could give some more information,inorder to narrow down the problem
as in what are you doing on the pc when it restarts
what is your pc configuration (dont leave out the smps,its very important)
what are the temp of cpu,mobo.. etc
fuzzz is offline
Old 15-04-2008, 01:10 PM   #3 (permalink)
slugger's Avatar
heating issues.....SMPS issue....many issues
plz elaborate
slugger is offline
Old 15-04-2008, 01:22 PM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
OR could be ram problem - dude give more details about your HW & SW config.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 15-04-2008, 03:06 PM   #5 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Yes, or maybe a darn virus, these problems seem to be cropping up the forum these days... post more about the configuration, what programs you have, what OS, since when this happened...
think we are police inspectors, give the FIR about the crime! tell whatever you know!
... or it could even be your kid cousin pressing reset when you arent looking
dheeraj_kumar is offline
Old 15-04-2008, 03:17 PM   #6 (permalink)
rameeze's Avatar
Ihave got solution
it was smps problem
thnx
rameeze is offline
Old 15-04-2008, 03:28 PM   #7 (permalink)
slugger's Avatar
Originally Posted by rameeze View Post
Ihave got solution
it was smps problem
thnx
plz elaborate
am i a psychic or wot
(do i hear sumbody sayin psycho)
slugger is offline
PC Restarts sachinc Hardware Q&A 12 23-01-2008 09:20 PM
Restarts every now and then aneesh kalra Hardware Q&A 4 09-02-2007 09:02 AM
Pc restarts navisangha Software Q&A 3 24-12-2006 04:12 PM
pc restarts itself niraj_dixit Hardware Q&A 5 24-05-2006 10:56 PM
Restarts the Pc!..... QnA (read only) 7 12-08-2004 01:11 AM
- by c4u
