Old 14-04-2008, 05:16 PM   #1 (permalink)
Default xfx mobo
hey are XFX mobo good nough...do they hav ny particular problem that i shld kno b4 i go 4 it..
hav zeroed on
XFX NFORCE 680I SLI
XFX nForceŽ 650i Ultra MCP
can nyone can quote da current lamington price?both models..n if these boards r avaliable in mum?
justin9180 is offline
Old 14-04-2008, 05:51 PM   #2 (permalink)
Default Re: xfx mobo
unless u want SLI , i wudnt recommend them . besides , the newer 780i and 790i have come out . if u dont want sli , p35 and x38/48 are better.
sagargv is offline
Old 14-04-2008, 06:31 PM   #3 (permalink)
Turn The Page
pannaguma's Avatar
Location: The name of the place where I live is too big to fit in this place, so I am not mentioning it !!!
^^man 780i is 14k .......... about 40% more than international price.
This Space Has Been "RESERVED" !!!
pannaguma is offline
Old 15-04-2008, 11:37 PM   #4 (permalink)
well wat xactly is SLI?u can use two graphic card at once?they share da load?isnt dat wat SLI does?
Old 16-04-2008, 10:47 AM   #5 (permalink)
^^ in a very simple manner , yes. . 2 nvidia cards requires SLI capable mobo which essentially has to have a nvidia chipset. .some intel chipset based mobo's offer corssfire but not SLI .. if u want SLI , then u will have to go for nvidia chipset . .if not , intel is better.
sagargv is offline
What do you think of this Mobo sg1 Hardware Q&A 7 01-03-2008 04:44 PM
sli mobo??? ayush rathi Hardware Q&A 18 09-07-2007 04:41 PM
which mobo to buy? bhoolkumehul Hardware Q&A 3 28-11-2006 03:28 PM
MSI mobo or INTEL mobo pls. help karthik316_2003 CPU / Motherboards 10 29-05-2005 03:29 PM
Pls. Help => Which MOBO ??? rachitboom2 CPU / Motherboards 11 23-03-2005 04:34 PM
- by c4u
