Old 12-04-2008, 09:22 PM   #1 (permalink)
Question Do SMPS's ( PSUs) have any compatibility issues with a UPS / CVT / Home UPS
To all Cooler master , Antec and Corsair PSU owners
Are you guys on a UPS / CVT or without it ?
Could you please post the make and ratings of your SMPS and UPSes / CVTs?
Please.
Thanks
PS 1: Very humbly I am requesting you all to spare some valuable time of your's and kindly let me know the details of your SMPS ( power Supply) and the UPS and / or CVTs you are using ( if at all you are using on / them ) .
PS 2: Am asking as I am planning to upgrade my SMPS , and my place is renowned for frequent power cuts , as of today I am on a local ( navtech , 450 watts ( so called ) SMPS and a so called home UPS from Microtek rated at 810 VA.
Somewhere on this site I read that PSU with a PFC ( power factor correction ) like the famous Corsair HX 620 watts , are not compatible with a UPS genrating a near sine wave .
Is it true ?
Do SMPS's have any compatibility issues with a UPS / CVT / Home UPS ( Inverter based )
Which power back up option and voltage stabilization / regulation option are peple here with a Corsair , Antec or Cooler Master SMPS ( with or without PFC ) excercising ?
What all are the feasible options for back up during power cuts ( which can be for hours ) for a person who wants a robust power supply like Corsair HX 620?
Thanks and regards
Big-G is offline
Old 13-04-2008, 08:29 PM   #2 (permalink)
Question Re: Do SMPS's ( PSUs) have any compatibility issues with a UPS / CVT / Home UPS
Why isn't anyone responding to this thread ?
Is it beyond everyone here ?
If not about the compatibility issue atleast folks here can mention their smps and ups / cvt combinations
Incase this thing has been enlightened anywhere else here or on some other site atleast give me the link .
Big-G is offline
Old 18-04-2008, 10:22 AM   #3 (permalink)
Dark Overlord !!!
rockthegod's Avatar
Default Re: Do SMPS's ( PSUs) have any compatibility issues with a UPS / CVT / Home UPS
Hi, just saw ur pm.... hate 2 say it but I dun have any of those brands u mentioned.. mine is PC Power and Cooling (a division of OCZ).. and I don't need any power backups where I'm living.. so sorry, am not sure about this compatibility that you are asking about. IMO, you should have at least 1 KVA UPS from APC if your system config draws out >600 W real power (true power in Watts).... ad supposedly you pair your config up with a LCD (Bump up UPS power rating O/P if you intend to use a monster CRT)
While I was living in India, my old config with a single 6800 GT/P4 HT 2.8 Gigs was paired with a 500W Corsair PSU and a 19" CRT.... never faced any problem with my 600 VA APC UPS (been using it for more than 2 years)...
C2Q6600@3.2G; eVGA nforce 780i; eVGA 8800 GT 512 MB (650/1900/1620) in SLi; 2 GB OCZ EPP DDR2 8500@1066M; PP&C Silencer 750W; Antec 900
AT&T Tilt WM 6.1 Pro Running Android
Sony PSP 2000 5.0-m33
rockthegod is offline
Old 18-04-2008, 10:32 AM   #4 (permalink)
Yup all the PSUs high end of course that give above 80% efficiency needs true sine wave as input which APC Back UPS cant provide. Only APC Smart series is compatible with such PSUs but those UPS' are damn costly.
I blew my PSU Corsair 620 Watt using with APC Back UPS 1000 VA
DOTA is really addictive :D
BULLZI is offline
Old 19-04-2008, 12:47 PM   #5 (permalink)
Hey Bullzi , I read about your corsair screw up and felt sad about it as I was myself planning to go for the same thing , psu as well as the UPS.
So what have you done now to rectify the things -
Are you using Corsair now ?
If yes then with which UPS and if no then which PSU are you using?
What is the cost of the true sine wave UPS of 1000VA , I guess it must be pretty high .
Big-G is offline
Old 19-04-2008, 02:31 PM   #6 (permalink)
cooler master extreme power 500W , apc 500va .no problems. what config do u intend to take ? is corsair hx620W needed ?
sagargv is offline
Old 19-04-2008, 11:46 PM   #7 (permalink)
sagargv
Does your PSU has an active PFC or a Passive PFC or no PFC ?
I see 2 models of 500 Watts on cooler master's site , one without any PFC and the other with a PFC but a passive one .
Bullzi's model is PFC and that is ACTIVE and hence the problem.
Here are the links -
http://www.coolermaster.com/products...e=2259&id=4017
http://www.coolermaster.com/products...e=2259&id=4015
Big-G is offline
Compatibility issues spyingshadow Hardware Q&A 4 22-06-2007 11:30 PM
Mac OS X Compatibility issues d Software Q&A 2 24-12-2005 01:19 AM
compatibility issues of AMD 64 bit dhawald CPU / Motherboards 2 19-12-2005 03:07 PM
compatibility issues hariharan QnA (read only) 4 13-12-2005 01:32 PM
Windows XP SP2 - Compatibility Issues terence Software Q&A 9 08-09-2004 10:21 AM
- by c4u
