Results 1 to 30 of 30
Thread: Sony DVD writer problem........
11-04-2008, 07:06 PM #1
Hi......
I have a Sony DVD writer bought before 6 months........
It was working fine............but now I am not able to read many DVD-R dvds even those which are playing well in my DVD player (Connected to TV).
It reads all digit dual layer dvds but fails in reading many DVD-R... When I put those in my drive...they show it as
total space : 0 & used space : 0 in properties.......
What shall I do..........I even have warranty.............Sony Xperia Neo V - Review and Discussion Thread:
http://www.thinkdigit.com/forum/mobi...ml#post1520514
11-04-2008, 08:26 PM #2
Re: Sony DVD writer problem........
You you are in warranty then replace the drive.
Who Dares Wins
Avenging Angel !
Phenom II 955BE↔Asus M5a97 R2.0↔Corsair 2x 4GB RAM↔HD6850↔Corsair GS600↔CM Hyper 212↔CM 430 Elite
My Blog : http://topgeartopspeed.wordpress.com/
BlackListed : Viewsonic, Gigabyte
17-04-2008, 11:13 PM #3
No........ I want to know if its possible........... Bcoz the person may put some other dvd format and it will work......... He might not beleve me...
18-04-2008, 09:12 PM #4
Try this and see if it helps :
Assuming those dvd's are video dvd's. Install K lite mega codec pack and insert the dvd when xp is loading.
Also some video dvd's have some issues with computer dvd drive i think.Who Dares Wins
Avenging Angel !
19-04-2008, 06:10 PM #5
I had the same problem along with that ther was also problem in Writing RWs too ... I updated my firmware and all the problems were solved.... Better go for a firmware update....
I am Back....
19-04-2008, 09:16 PM #6joy.das.jdGuest
Well if the G170 series writer then you MUST go to the dealer and get it replaced.. Believe me even i had problem with that model of the sony DVD writer and i got are placement for the drive. But try the firmware update first.It might solve your problem without going to the dealer
20-04-2008, 11:58 AM #7
Yes, flash G170 to AD-7170A firmware. it works for me.
21-04-2008, 01:01 PM #8Alpha Geek
- Join Date
- Aug 2007
- Posts
- 501
in case u r interested, you could look at http://liggydee.cdfreaks.com/page/en/Optiarc-AD-7170A/
21-04-2008, 07:30 PM #9
Yeah try to flash the drive - that might work
Who Dares Wins
Avenging Angel !
21-04-2008, 08:07 PM #10
Yeah flashing the drive might work
Regards,
The Conqueror
22-04-2008, 04:56 PM #11Alpha Geek
- Join Date
- Aug 2007
- Posts
- 501
try a dvd lens cleaner...flash the drive
i doubt they will work
sony current range of optical drives should be avoided at all cost...i have one of those..and it has the same problem with no solution and this forum should have a section dedicated to optical drives showcasing problems reported by people for each model warning potential buyer off it
i have the sony dru-810a which is still running strong and the sony dru-170c (optiarc one rebranded i think)newer one has lots of problem and chip pr digit gave it a high score if i remember it correctly...damn!
22-04-2008, 06:22 PM #12
Thats because..performance wise its till one of the best in the market !
Here are your options.A firmware update may solve your problem but chances of that are slim.If its a AWG-170 drive (DRU 170C) then the latest firmware is 1.74.(You wont find this update on sony website..i got it from cdfreaks.) Update it and see what happens.
If your problem is bot corrected then get it repaired form service centre.
And for your unreadable DVD-rs ..use isobuster..you will probably recoever the data. Thats because this problem happens only in win32 environment..in dos mode it works fine.
If yoy dont have the latest firmware and the flashing tool..ask for it to me..I can provide that...but use it at your own risk
22-04-2008, 06:35 PM #13Alpha Geek
- Join Date
- Aug 2007
- Posts
- 501
yes that the problem with these ratings and many such online...it cannot reveal what happened after a passage of time..the thing is stress testing is not part of it if im not wrong...
it is fast but it is also ages fast
22-04-2008, 06:56 PM #14
Yes.............its the same DRU 170C............................
I had never had problems with sony drives... Thats why I went into buying that.........
Anyway......thanks a lot 4 all of u........
I will try all solution
BTW, mine is DRU-170C..........
Can u give me the link for that firmware?????Last edited by damnthenet; 22-04-2008 at 06:56 PM. Reason: Automerged Doublepost
23-04-2008, 02:25 PM #15Alpha Geek
- Join Date
- Aug 2007
- Posts
- 501
firmware 1.73
http://liggydee.cdfreaks.com/disclai..._orig.zip.html
for a full list go below
just find original sony.....
windows based flashing tool
http://binflash.cdfreaks.com/
23-04-2008, 06:35 PM #16
Yep, Liggy-Dee have the best firmwares, I solved my problem by flashing a AD-7170A RPC1 firmware, you can try that if your drive is AW-G170A.
23-04-2008, 07:15 PM #17
I will better try claiming warranty first as doing the expt. w'd result in losing the warranty...
I case I do not get it replaced......I will try this............
Anyway thanks a lot........ I never knew about all this earlier.Sony Xperia Neo V - Review and Discussion Thread:
23-04-2008, 08:45 PM #18
23-04-2008, 09:41 PM #19
change the pata cable .that would probably work
Apple Macbook Pro 17 :cool:
23-04-2008, 09:58 PM #20
After installing 173_rpc1 DVD Decrypter is not detecting my AW-G170a Drive.
N Changing cable will not make any job.....
23-04-2008, 10:33 PM #21Alpha Geek
- Join Date
- Aug 2007
- Posts
- 501
23-04-2008, 11:23 PM #22
Plz Provide the link to 1.74
24-04-2008, 12:58 PM #23
check if those dvd`s r multisession 1`s ......
install isobuster & try reading dvd`s through it .......
do those dvd`s work on ur frds pc ?... W H O T ...
24-04-2008, 02:49 PM #24
Both multisession and non-multisession DVD-R dont work............. they work in other PCs.......
24-04-2008, 07:29 PM #25
Why don't post a e-mail to sony support service regarding your problem. They might have the solution.
Who Dares Wins
Avenging Angel !
25-04-2008, 05:41 PM #26
Naah, this is a very common problem with Optiarc drives... Either flash your firmware or exchange for another drive, those are the only solutions.
26-04-2008, 02:24 AM #27
26-04-2008, 01:17 PM #28
did u try checking THEM with isobuster ....
as they work with other pc`s ..... so, install updated firmware ....... W H O T ...
26-04-2008, 09:38 PM #29Right Off the Assembly Line
- Join Date
- Apr 2008
- Posts
- 7
My drive is the same RW G170-A. Here is my firmware (version 1.74).
http://rapidshare.com/files/103875623/AWG170A_1.4.rar
Me too having the same problems with this drive (cannot read many of my DVDs). No problem with the writing!!!
27-04-2008, 01:02 AM #30Alpha Geek
- Join Date
- Aug 2007
- Posts
- 501
i think all those who have the g170a which is having problem reading or writing the dvd and out of warranty should collect it and together chuck them at sony office
dvd writer problem sony Sony AW-G170A
By brijand in forum Hardware Q&AReplies: 6Last Post: 25-07-2008, 11:35 AM -
Problem with Sony DVD writer
By webgenius in forum Hardware Q&AReplies: 2Last Post: 16-01-2008, 07:58 AM -
Sony DVD Writer Problem
By sumeetindia in forum Hardware Q&AReplies: 3Last Post: 27-03-2007, 01:02 PM -
By godling in forum Hardware Q&AReplies: 8Last Post: 07-03-2007, 05:59 PM -
By mako_123 in forum Hardware Q&AReplies: 13Last Post: 06-08-2006, 08:34 PM
LinkBack URL
About LinkBacks
