Old 11-04-2008, 06:23 PM   #1 (permalink)
Exclamation System Problem - Please help
Hi all,
I am new guy here.
My system is not starting up, when i press the power button. (I have connected the cable and the power switch is on).
Will thr be any problem with the SMPS. I checked the power is coming from the UPS. so, i concluded that thr is no problem with the UPS.
My System config:
Pentium D Processor 925+ - 3ghz 800 mhz
Jetram - 2*1gb - ddr2
Thanks in advance
kirthi2008 is offline
Old 11-04-2008, 06:32 PM   #2 (permalink)
ionicsachin's Avatar
Default Re: System Problem - Please help
open the cabinet and see if the cpu fan and other fans are working....if they rnot working then maybe its smps prob
My first song
http://rapidshare.com/files/128849730/Sachin_-_In_My_Dreams.mp3
http://cid-e2d4f861e716a7fe.skydrive.live.com/self.aspx/.Public/Sachin%20-%20In%20My%20Dreams.mp3
ionicsachin is offline
Old 11-04-2008, 08:29 PM   #3 (permalink)
Fast 'N' Furious
topgear's Avatar
What do you mean by :
You connected the smps cable with motherboard while the ups swith was in the on position ?
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
System having a big problem smile Software Q&A 5 10-12-2007 12:18 PM
System Problem ????? smile Software Q&A 4 27-11-2007 03:52 PM
problem with my new system paul_007 Hardware Q&A 11 26-03-2007 10:04 PM
System Problem doom_marine Hardware Q&A 11 28-05-2006 01:29 PM
System Problem, help please !!! rahuljin Hardware Q&A 20 10-05-2006 09:13 PM
- by c4u
