10-04-2008, 07:22 PM
mannuforall
Broadband Setup Problem
hi!
guys I have bsnl broadband connection but I unable to configure and connect since re installation of XP SP2. I need help to configure type I modem (model no. C2110) from SIEMENS which provided by bsnl. It connected via usb. After installing modem driver successfully, I make a connection but it cannt connect to net.
please help me to setup the Modem......
My TCP IP Settings is:
IP Address: 192.168.1.2
Subnet mask: 255.255.255.0
Gateway: 192.168.1.1
Preferred DNS: 61.1.96.69
Alternate DNS: 61.1.96.71
Manojr Tiwari
http://www.mannuforall.in
You can also contact me for any UC Browser related info.
10-04-2008, 11:34 PM
TechTin.com
Re: Broadband Setup Problem
Ping 192.168.1.1
and post the result.
10-04-2008, 11:57 PM
Evolving Rapidly...
open modem settings page from web browser, go to conn, set user name ->phno, pass ->ca no. [works for mtnl]
http://qbitmesra.blogspot.com - Quenching BIT's Quriosity
"Female sexuality isnt a myth" - what i learnt in my first year at college
11-04-2008, 12:25 AM
TechTin.com
reinstalling XP should not affect modem setting.
11-04-2008, 01:02 AM
type address below mentioned in internet explore address bar and enter
http://192.168.1.1
after that it will ask for user name and password type user name : admin
and password : admin which is default user name and password.
Then there will be wan configuration,
configure PVC - 0 with user name and password given by BSNL
then apply modem will reboot and it give the status of the connection.
11-04-2008, 03:35 AM
Dont Give Ur Ip Address U Can B Hacked.......
11-04-2008, 04:59 AM
Lets Do It!
Its all same for the BSNL ones.
BTW 'IP Address' and his IP Address are different.
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
11-04-2008, 05:03 AM
Point Blanc
are you trying to do BSNL setup first time or what.
in DNS server you need to put 192.168.1.1, because your modem will be your DNS server.
Other than these do you have your login password given by BSNL.
If there is really anything wrong with the modem(if you are not doing first time setup) then you can reset your modem to factory settings. Every router and modem has pin port.
But before this follow what girish says, and see in the page there would be option for restarting the router. I say this because I havent tried resetting my router to factory settings any time, no need to as its working fine.
Reason: Automerged Doublepost
11-04-2008, 05:51 AM
i thought its his....
11-04-2008, 06:10 AM
Indidiot
If ur using home plans no need for IP address Bullshit. Instead in network settings option select "Obtain IP Address Automatically" and "Obtain DNS address automatically". And why the hell do you need to **** up with USB port can't U connect it using LAN port like normal guys do
11-04-2008, 07:47 AM
mannuforall
Thanks you all for quick response but problem is still. On typing http://192.168.1.1 in browser does't opens anything.
also on ping 192.168.1.1 it does't show any error.
Manojr Tiwari
11-04-2008, 09:18 AM
TechTin.com
Originally Posted by paid
why are you guiding in wrong way.
Both USB and LAN will have same default gateway..which is IP address of modem.
start -->> run -->> type cmd -->> ok
In command prompt type :
ping 192.168.1.1
and post the result you are getting.
11-04-2008, 07:11 PM
mannuforall
ping 192.168.1.1 gives reply from 192.168.1.1
Manojr Tiwari
11-04-2008, 08:55 PM
TechTin.com
Ok..
that proves connection between system and modem is OK.
Now..in browser type 192.168.1.1
You will be asked username and password.
username -> admin
Password -> admin OR password
Click on WAN from left menu and post the status.
11-04-2008, 10:42 PM
mannuforall
It does't opens any thing.
Manojr Tiwari
11-04-2008, 10:56 PM
TechTin.com
are you using any firewall.
Disable all firewall.
Open IE -->> Tools -->> Internet option -->> connections
1) delete all connection if there is any in the box.
2) select never dial a connection.
3) click LAN setting -->> uncheck all boxes -->> apply OK
save settings, and now try to open 192.168.1.1
12-04-2008, 02:59 PM
mannuforall
Sorry, but one thing also I wants to tell you, My system has win XP SP 1.
Is this affect anything? Is there a need to install XP SP 2.
Manojr Tiwari
12-04-2008, 03:57 PM
TechTin.com
SP2 is not a requirement for BB, but it will be nice if you can upgrade to SP2.
13-04-2008, 03:32 PM
#19 (permalink)
mannuforall
Thanks to all of you! After installing win XP sp2, my broadband connection is working very fine. Now I'm enjoying my high speed internet. Thanks for helping me and for your quick response.
Also I wants to inform you after installing modem software, I just make a new connection, enter user name and password and without any config & ip address it connected successfully.
Manojr Tiwari
