Old 09-04-2008, 02:38 PM   #1 (permalink)
Mad and Furious
redhat's Avatar
Default will 1 2gb ddr2 ram be compatible wid my pc?
I have a Intel Pentium 4 processor, 2.80ghz...
will a 2gb DDR2, 667mhz ramm be compatible with this???
Please tell me fast, since I wish to go n buy it today itself...
My new Tech Blog : http://technewspaper.blogspot.com/
redhat is offline
Old 09-04-2008, 02:41 PM   #2 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Default Re: will 1 2gb ddr2 ram be compatible wid my pc?
http://www.thinkdigit.com/forum/show...638#post798638
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 09-04-2008, 02:49 PM   #3 (permalink)
Fullbring
Zangetsu's Avatar
ok...ok...chill
from next time dont double post....
to chec which chipset u r mobo has
do:
ryt clic on desktop > select properties > settings > advanced >
then chose adapter tab > see the chipset name uder adapter type.
dats it....
Zangetsu is offline
Old 09-04-2008, 11:33 PM   #4 (permalink)
TooR
alok4best's Avatar
First, it depends on ur Mobo..
considering u have a P4 2.8Ghz proc, I think ur board supports only DDR1.. as at that time(the socket 478 era) there were no boards having support for DDR2.
I wish !!
alok4best is offline
Will a 2gb DDR2 ram be compatible wid my PC redhat QnA (read only) 9 09-04-2008 02:56 PM
S 1GB DDR2 @667MHz COMPATIBLE WITH 2GB DDR2 @800MHz amrawtanshx QnA (read only) 1 10-03-2008 08:57 PM
Is my PC 64 BIT compatible ayushman9 Hardware Q&A 6 28-01-2008 09:11 AM
Is DDR2 667 and DDR2 553 mhz works together..? amolwable Hardware Q&A 9 22-12-2007 08:30 PM
Is JDK 1.5 compatible with Tomcat 5.5.9 s4saurabh Open Source 1 26-05-2005 01:52 PM
- by c4u
