Old 09-04-2008, 09:46 AM   #1 (permalink)
Point Blanc
Default Sony IDE DVD Writer DW-Q120A issue
I had put this in a IDE box and using as external writer.
I last used it about 4 months back.
Now when I am trying to use it to write its not working, though its reading well. THe IDE box I am using is gemini supplied 5.25 external casing.
I think it may be power issues so going to buy new power adapter for it. But I need if anyone can give me any help for this.
Secondly I wanna know good IDE based DVD writer, because I had tried to put my writer directly into a PC but seems it was working there also.
acewin is offline
Old 09-04-2008, 04:42 PM   #2 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Re: Sony IDE DVD Writer DW-Q120A issue
4 whot price didya get that box ? .... how didya handle it ?
check ur ritter by attaching it in ur system .....
sony is the best .....
... W H O T ...
ax3 is offline
Old 09-04-2008, 06:51 PM   #3 (permalink)
Point Blanc
well actually I dont have any system I had attached it to my friends system.
It was able to read very well but couldnt write properly.
THe casing I bought in Rs 750, and for last 4 months I hadnt used my writer.
Everything works really fine, and I was glad I could write with it at full 16x
http://shopping.rediff.com/shop/prod...rfnbr=10159039
You can check the looks of my casing from the link I have given but thats not the actual price
acewin is offline
Lite-ON dvd writer issue: HELPPPPPPPPPPPPPP Desperado Hardware Q&A 9 07-04-2007 03:31 PM
sony vaio shutdown issue legolas QnA (read only) 5 09-02-2007 08:01 AM
Extremely Bizarre DVD writer issue !!! NikhilVerma Hardware Q&A 8 20-10-2006 05:04 AM
Which dvd-writer sony dw-q120a or sony dru-820a its urgent anirudhasarawgi Hardware Q&A 3 27-05-2006 05:47 PM
Sony DW-Q120A Problem... anilthomas26 Hardware Q&A 5 17-05-2006 01:08 PM
- by c4u
