Old 09-04-2008, 09:44 AM   #1 (permalink)
Thor's Avatar
Angry Laptop Freezes and starts working again , sometimes .. :(
Hi,
I bought my Compaq V3425AU last july31st. It came preinstalled with Windows Vista HOME basic.
Its specs :: AMD X2 1.7Ghz. 1 GB ( 2 x 512 ) DDR2 667 Mhz, Geforce Go 6150 onboard, 160 GB HDD, DVD+-RW .
Obviously to get my system to work fastest i dual booted with Windows XP Pro SP2. Along with drivers.
Now its been almost 8 months since I installed XP and the laptop was working fine untill recently. Recenly , my laptop HANGs / Freezes suddenly for no reason.
It happens Randomly, Browsing, listening to music, or simple Coding time! But after a min or so , I can get it to respond again . This repeats everu now and then
AND , while playing the Game Command and Conquer 3 Tiberium Wars Kane Edition, it freezes extremely ! The Screen draws a Hazy colored White Blank! And It never Unfreezes have to reboot!
And this though happens rarely , happens while doing anything! Like suddenly inbetween a chat , it draws me a white screen! I have taken a picture too!
Also sometimes during reboot , I dont get a POST.
That happens rarely , but it does happen! I have tested by disconnecting the AC power adapter and attempting to boot on Battery , and it boots fine then. :O wierd!
Any Idea on the 1st and 2nd problem ? and why is this happening ?
regards!
Beware of my Wrath Mortals, Thou hast no choice.
Thor is offline
Old 09-04-2008, 11:14 AM   #2 (permalink)
At Hell's Disq
hellgate's Avatar
Default Re: Laptop Freezes and starts working again , sometimes .. :(
1.update bios to latest release.
2.if u dont hav antivirus installed then reinstall windows.
hellgate is offline
Old 09-04-2008, 11:50 AM   #3 (permalink)
PhotonAttack
DigitalDude's Avatar
prob 1) upgrade to the latest graphic drivers.. do a memory integrity test.. and check for HDD bad sectors..
prob 2) again check your memory and also try replacing the CMOS battery...
if this doesnt work.. there will be an option in the BIOS to whether show the POST screen or not.. see that..
you can either use any diagnostic CD that came with your compaq laptop or use hiren's ultimate boot CD
_
In a time of universal deceit, telling the truth is a revolutionary act - George Orwell
|| तमसो मा ज्योतिर्गमय ||
DigitalDude is offline
Old 09-04-2008, 06:43 PM   #4 (permalink)
thats a poor lappy my frnd
it doesn't have a laptop proccy but a desktop proccy in athlon x2.
u will run into high temps , low battery life , instable laptops wid such processors.
u shuld have chosen a lobile processor like turion
compiling_error is offline
HP Pavilion laptop camera not working vikasg03 Laptops and Netbooks 4 30-05-2008 12:22 PM
PC Starts -> Switches Off -> Starts godsownman Hardware Q&A 10 08-02-2008 08:39 AM
Windows starts physical memory dump every time Skype starts (blue screen of death) mightyboosh Software Q&A 9 20-12-2007 02:42 AM
laptop usb2.0 not working as per the rated speed. ranjan2001 Hardware Q&A 4 19-09-2007 06:57 PM
Help needed- ibm laptop combo drive not working shivkumar Hardware Q&A 3 20-08-2006 04:27 PM
- by c4u
