Old 08-04-2008, 04:56 PM   #1 (permalink)
TDF Sucks
Default What to buy??
im buying parts for a new gaming rig.budget of 50-55k.just want to buy case n what goes in it and vista included in budget.my starting point is MSI Geforce 9600 OC edition w/ dual slot cooling and e8400 C2D processor+Artic cooling mx-2 n Thermalright U120E
Extreme Gamer is offline
Old 08-04-2008, 06:06 PM   #2 (permalink)
TDF Sucks
Default Re: What to buy??
anyone????!!!!!!!!!!!!plz help!im up grading from parts which are dinosaur now
Old 08-04-2008, 07:12 PM   #3 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
good budget and i'd suggest a Quad core instead - which will be great for some near future games
Board=MSI P7N Sli if u wanna add another gfx card , otherwise Abit IP 35 PRo
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 08-04-2008, 07:14 PM   #4 (permalink)
TDF Sucks
no sli for me
and msi is better than abit.they use solid state capacitors,which last longer and perform better.as for quad,i dont need one since the only game that supports quads w/o modding is crysis and crysis performs beter in duals.and i need specs for case and everything that goes in it.
also i will OC a lot cpu 4ghz and gpu to as much as possible without pencil mods or volt mods
Old 08-04-2008, 07:57 PM   #5 (permalink)
Alter Bridge=GOD
well new games will definitely support quad core processing, thats ur wish
Abit also has solid state capacitors in IP 35 Pro !!
Old 08-04-2008, 11:46 PM   #6 (permalink)
mayanksharma's Avatar
Nice budget!
Well, MSI Platinum P35 Combo + Q6600 should be a nice combination. Regarding RAM, go for atleast 2GB from Patriot/Corsair. Yep, MX-II combined with U120E should be good. Btw, also lookout for CoolerMaster Gemini II or Hyper 212. They are nice in performance.
Regarding GPU, go for Palit 9600GT Sonic edition, if possible. The card is way better than other OC versions. Btw, with that budget, i suggest to go with a 8800GTS 512MB. Way better than a 9600GT! One more thing, make sure u invest in a good Cabinet, like CoolerMaster Cosmos!
mayanksharma is offline
Old 10-04-2008, 01:37 PM   #7 (permalink)
TDF Sucks
full specs plz
i decided on CM690 coz i wont need full tower case
Last edited by Extreme Gamer; 10-04-2008 at 01:37 PM. Reason: Automerged Doublepost
Old 11-04-2008, 02:57 PM   #8 (permalink)
ok, what would u need to know with that already i've told.
I've even mentioned the brand particulars!
Old 12-04-2008, 01:01 PM   #9 (permalink)
TDF Sucks
how about this spec list?
intel Core 2 Duo E8400 Processor
MSI P35 NEO-F Motherboard
MSI 9600GT OC Edition(Dual Slot Version) Graphics Card
Seagate Barracuda 7200.10 320 GB(16 MB Buffer) HDD
Cooler Master CM 690 Case
Tagan BZ700 700W Modular Power Supply
G-Skill DDR2 F2-6400CL5D-4GBPQ(2GB x 2) 800Mhz RAM
ThermalRight Ultra 120 Extreme CPU Cooler (using Arctic Silver 5 Thermal Paste)
Scythe Kaze-Jyuni SY1225SL12SH - 120mm(x4) Case Fans (added with stock fans)
Windows Vista Home Premium (64-bit) OS
Old 12-04-2008, 01:17 PM   #10 (permalink)
heartripple's Avatar
Smile Re: What to buy??
your configuration is very good but if you would like to make some changes will give you better performance
go for ati cd 3870 or 3850 this graphics card is better than 8800 and 9600
go for q 6600 instead of 8400 it's more future proof.
heartripple is offline
Old 12-04-2008, 01:27 PM   #11 (permalink)
I would prefer Noctua 120mm-1300 RPM fans attached to TRUE for best cooling.
AMD Phenom II X4 955 BE, Asus M4N98TD EVO, 2x2 GB G.Skill @ 1600MHz, MSI GTX 560Ti Hawk, 500GB Western Digital Black SATA-II, Dell Ultrasharp U2311H, CM 690, Corsair VX550
monkey is offline
Old 12-04-2008, 01:33 PM   #12 (permalink)
Alter Bridge=GOD
I'd suggest
Intel Q6600
Western digital 320GB AAKS
Abit Ip35-E
Rest all same.
Old 12-04-2008, 01:49 PM   #13 (permalink)
TDF Sucks
@monkey:so i should go for those fans instead of scythe?what do they cost?
@nish:i dont want something future proof now for i will go for LGA1336 after 2-3 yrs.i abit is hard to find in kolkata.msi has better customer support.i am not saying that abit is bad,but i prefer msi.WHATS THE COST OF THE HDD?has it got 16mb buffer?
Old 12-04-2008, 02:01 PM   #14 (permalink)
Alter Bridge=GOD
yes it has 16mb buffer and will cost just about the same.
E8400 is good but if you gotta overclock it to the max ,u'd need a good mobo.if its MSI i'd suggest going for a P35 NEo combo atleast or a P7N Sli platinum.
the board you selected does not seem to have any good capacitors or overclocking features.
Those scythe fans are good .i have the same thing with my thermalright 120E
Old 12-04-2008, 02:07 PM   #15 (permalink)
TDF Sucks
ok heres a re list:
Abit IP-35-E Motherboard
WD Caviar SE16 320GB HDD
Old 12-04-2008, 02:11 PM   #16 (permalink)
Alter Bridge=GOD
perfect , and if possible add a corsair dominator ram cooler if u r overclocking those rams .it will help a lot keeping them cool
Old 12-04-2008, 02:12 PM   #17 (permalink)
TDF Sucks
i dont oc ram modules.
oh and whats electric stove edition?dont tell me that u use your gfx card for cooking food!
Old 12-04-2008, 02:43 PM   #18 (permalink)
Wire muncher!
infra_red_dude's Avatar
Spot one!! How did you know that he cooks his food on his XFX card??? Actually that card is known ot haf heating issues.
Quite nice setup you've decided to go for, I must say
infra_red_dude is offline
Old 12-04-2008, 03:33 PM   #19 (permalink)
Alter Bridge=GOD
^ at 80 degrees of non-oc gaming temp i guess u can cook
maybe XFX had the same idea when designing 8600gt,gts ,8800gt alpha dog
Old 12-04-2008, 03:38 PM   #20 (permalink)
TDF Sucks
actually nish,go for aftermarket heatsink for your gfx card
Old 12-04-2008, 03:49 PM   #21 (permalink)
Alter Bridge=GOD
i do have antec Vcool but i'm changing my gfx card pretty soon.going for a 9600GT sli or a 9800gTx
Old 12-04-2008, 03:50 PM   #22 (permalink)
TDF Sucks
9600GT sli beats single 9800gtx
Old 13-04-2008, 12:52 AM   #23 (permalink)
Pretty nice specs u came up with.
And well, 9600GT in SLI setup should beat a 9800GTX. Instead of buying a 8800GTS for ~17-18.5K, it would be wise to invest in two 9600GTs!
One more thing, go for WD HDD if possible. Possibly, ones with 16MB cache, like others have suggested.
Regarding PSU, i thought CM Real Power 550W should be appropriate. And, instead of AS5, go with MX-II. AS5 is gr8 for GPUs. U120E is a good choice.
So, when are you going to buy the rig?
Old 13-04-2008, 09:20 AM   #24 (permalink)
TDF Sucks
no idea when i get the money?!:d probably in a week or so
- by c4u
