Old 08-04-2008, 02:56 PM   #1 (permalink)
channabasanna's Avatar
Default LAN between Vista laptop and XP SP2 PC
Hi All,
I have hp laptop dv2601tx with pre-installed Vista Home Edition. I want to create a PC-Laptop LAN. I have 2 cross over ethernet cable.
At home i use BSNL broadband Internet, in my motherboard i have 2 LAN ports, one of the LAN port i have set it to the BSNL router (IP 192.168.1.100) and other port i have set it to 192.168.1.101, with Subnet Mask 255.255.255.0, in my laptop i have set the IP to 192.168.1.102.
Whenever i connect the Ethernet cable and enable the network it says Connection successfull in my PC (XP), and Limited Connectivity in Laptop (Vista), when i try to ping from PC to Laptop i get request timed out error.
Again i removed the ethernet cable and put it into the LAN Port, now it shows Cable unplugged.
can i know what i should do to create my Network.
channabasanna is offline
Old 08-04-2008, 06:28 PM   #2 (permalink)
Default Re: LAN between Vista laptop and XP SP2 PC
Guys please help me, i wanna play few games on LAN and use internet together, using both the machines.
C2Q Q6600 G0|ASUS Maximus Formula|XMS2 1GB x2|CM extreme Power 600W|CM Elite 332|WD 320GB HDD|Seagate 80GB HDD|SONY DVD+RW|Viewsonic VA1912wb 19"|XFX 7600GS|OCZ Vendetta 2|HP dv2601tx|Nokia N73 ME
Old 05-11-2008, 06:53 AM   #3 (permalink)
check out this tutorial on connecting systems via cross over cable
CONNECTING VISTA LAPTOP TO XP DESKTOP USING ETHERNET CROSSOVER CABLE
techtricks.co.in
portforwarding
xp-vista crossover connection
installing xp on vista notebooks
sreenidhi88 is offline
Old 05-11-2008, 09:33 AM   #4 (permalink)
Designer Here
techking_dinesh's Avatar
well my router has only 1 port so i dont know how to connect so as t oshare internet
but i can help u with game thing
connect the cable in ur cpu and laptop forget the router
keep the settings as
on pc:
ip: 192.168.1.1
subnet: just press tab after entering ip it will come auto
default gateway: 192.168.1.2
on lappy
ip: 192.168.1.2
default gateway: 192.168.1.1
Click on obtain dns server automatically in both cases
Just refresh and now u r connected to play games
** Connecting internet will also be simple but i haven`t tried it so would not like to advice regarding it **
techking_dinesh is offline
Old 05-11-2008, 11:33 AM   #5 (permalink)
At Hell's Disq
hellgate's Avatar
to create a lan connection between Vista and XP u need to download and install the LInk Layer Topology driver for XP.only then shall u be able to create a successful lan connection.
hellgate is offline
installing windows xp on vista laptop raja2281 Hardware Q&A 2 23-01-2008 03:43 PM
Can I Buy 1 Vista n Install it in my both PC& Laptop? Ganeshkumar Laptops and Netbooks 42 24-05-2007 12:43 PM
Laptop Vista yash20_shah Laptops and Netbooks 3 08-06-2006 02:44 PM
Will my laptop support Vista? pickster Laptops and Netbooks 3 18-03-2006 06:47 PM
Buying Vista Compatible Laptop dragonlord Laptops and Netbooks 8 25-02-2006 10:17 AM
- by c4u
