Old 07-04-2008, 11:16 AM   #1 (permalink)
Default Issue With Lcd Monitor
Hi all
I have been using a 17' Viewsonic LCD monitor since 6-8 months and have not faced any problems. For past month or so I have observed that when I switch on the mains, the LCD screen starts to glow even when its power-on button is in 'off' position. It glows even when the computer is in sleep mode.
However when working, the display etc is ok.
I've been told that this has something to do with crystals getting magnetized and it becomes alright on its own.. I would appreciate if someone could explain this and if this needs to be corrected by an engineer..
Thankyou
harmads is offline
Old 07-04-2008, 05:10 PM   #2 (permalink)
Intel OCer
amitash's Avatar
Default Re: Issue With Lcd Monitor
is ur monitor connected to the cpu power outlet or a separate one??my 19' viewsonic is connected to an external power source and ter are no problems...try doing tat to ur monitoror try turning off all the switches to which ur comp is connected to...
My site: collegeclassroom.org
amitash is offline
Old 10-04-2008, 04:10 PM   #3 (permalink)
Amitash
Thankyou for your reply..I will check that out.
harmads is offline
There is a ghost in my monitor!!!Monitor going crazy!!!!!!need help..... tango_cash Hardware Q&A 1 13-12-2007 12:03 PM
RAM Issue.... bad_till_bones Hardware Q&A 6 28-01-2007 11:45 AM
RAM Issue speedyguy Hardware Q&A 13 20-01-2006 06:11 PM
HELP NEEDED FOR MONITOR ISSUE mandar5 QnA (read only) 2 30-09-2005 08:57 AM
Monitor and Monitor Power Light is blinking aathif QnA (read only) 4 21-05-2005 05:20 PM
- by tv6952
- by Charley
- by soumya
