Old 07-04-2008, 12:31 AM   #1 (permalink)
Living to Succeed
ajayashish's Avatar
Default ATI 3870X2 and 3D Max
anyone here using ATI 3000 series with 3D applications like 3D Max and Maya... i just want to know if it works fine as it works with Nvidia card... i will be buying it next weekend so just wanted to make sure i dont make a bad buy
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
ajayashish is offline
Old 07-04-2008, 02:30 AM   #2 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Default Re: ATI 3870X2 and 3D Max
gx_saurav is using HD3650 with max.......... without any problem, so you can safely go on with your purchase. Don't know if it's the same case with MAYA but it should work without any hiccups.
I also had that same doubt but after GX experience, its all cleared.
@gx
please comment
john_the_ultimate is offline
Old 07-04-2008, 02:37 AM   #3 (permalink)
Living to Succeed
ajayashish's Avatar
I will be goinbg with HD3870X2 card
Old 07-04-2008, 05:18 PM   #4 (permalink)
Intel OCer
amitash's Avatar
its an awesome card and imo ters noprob with 3D apps...get the gecube OC edition if u want to overclock..at 99% load(crysis) mine only runs at 57-60C...and how much are u paying for it???
My site: collegeclassroom.org
amitash is offline
Old 07-04-2008, 05:58 PM   #5 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
3870X2 is an awesome card....currently best out there !
Username Changed - BlackBerry7100g To BBThumbHealer !
BBThumbHealer is offline
Old 07-04-2008, 06:39 PM   #6 (permalink)
deathvirus_me's Avatar
3870 is already softmoddable ...
deathvirus_me is offline
Old 07-04-2008, 09:58 PM   #7 (permalink)
Living to Succeed
ajayashish's Avatar
ok then i am going for Ati 3870X2 card... thanks guys
Old 07-04-2008, 10:15 PM   #8 (permalink)
The G-Axe Effect
gxsaurav's Avatar
ATI Radeon HD 3xxx series graphics card is not from nVidia
I am using Radeon HD 3650 with 3Ds Max in DirectX 9 mode as well as OpenGL mode, there is no problem what so ever, I m also running the newly released trial version of 3Ds Max Design 2009 which works with Aero unlike previous versions. In DirectX 9 mode 3ds Max 2009 works flawless with my card, although 5 billion polygons is a limit I would say after which the view port starts to slow down.
Graphics & Web Designer - SlideShare
Portfolio & Blog : http://gxsaurav.com
gxsaurav is offline
9600GT SLi Benchmarks , BEWARE( 3870X2) ! ! ! saggygenius Technology News 8 01-03-2008 01:57 PM
