Old 07-04-2008, 12:15 AM   #1 (permalink)
Tech.Masti's Avatar
Default 150 feet distance, can i make a LAN? How?
me and my friends house distance is near around 150 feet, we want to make a LAN, is this possible with RJ-45 and CAT-5?? if yes tell me what we need??
if not possible then tell me any other way to make it. if possible tell me also approx. expenses...
Thanks in Advance
Tech.Masti is offline
Old 07-04-2008, 01:06 AM   #2 (permalink)
slugger's Avatar
Default Re: 150 feet distance, can i make a LAN? How?
AFAIK, the max allowable free lenght of ethernet cable is 100 m (300+ ft)
so it should work without hitch
but my suggestion is to wait for another, confirmed reply
slugger is offline
Old 07-04-2008, 01:09 AM   #3 (permalink)
Tech.Masti's Avatar
^^ thanks, but AFAIK this is theoritical, is this happen practically?? and do i need any repeaters or something??
Old 07-04-2008, 01:37 AM   #4 (permalink)
|| तमसो मा ज्योतिर्गमय ||
DigitalDude's Avatar
nothing extra is needed.. this is a small distance only... just connect directly..
and dont forget to get the PC to PC ethernet cable a.k.a cross-over cable (if connecting PC to PC) or else get the normal cable if you are using a router to connect the PCs...
the network will be good when you have a router... becomes hassle free or else you have to deal with small small problems in directly connecting two PCs over LAN
p.s. an ethernet repeater is needed only for very long distances...
_
DigitalDude is offline
Do ur feet stink - tension not RBK has the solution iMav Random News 8 22-02-2008 12:23 AM
Vista still struggling as Linux finds its feet Cyrus_the_virus Technology News 44 29-11-2007 03:59 PM
MCA as Distance Education int86 QnA (read only) 8 17-06-2007 01:08 PM
IS distance metters in LAN? vikasg03 Networking 17 27-07-2006 10:16 PM
what is maximum distance for lan jigar657 Networking 6 24-03-2005 01:36 PM
