| Forum |
#1 (permalink) |
mortal kombat
well i have a 512mb ddr ram of 160.6mhz. now if i put another 1gb ram.should its frequency be the same of that of 512mb ram?? well i need some suggestions from you.should i remove the old 512mb and add the new 1gb. or can i use both simultaniously. |
#3 (permalink) |
Fast 'N' Furious
Dude post what mobo do you have 1st.
Your ram speed should be 166 mhz ( aka 166 *2 = 333) Mhz. Check your bios. So get a new 333 Mhz ram module.
ToPsPeEeD = FaSt BuT StEaDy AMD Radeon HD 6850 OverClocked to 1 Ghz !!! Blog : http://topgeartopspeed.wordpress.com/ ---------------------------------------------------- Never buy viewsonic products : http://tinyurl.com/ykwx4oa |
#4 (permalink) |
|| तमसो मा ज्योतिर्गमय ||
yes cpu-z shows half the speed... so your ram must be 333 Mhz
and the frequency can be same or more... even if you get some ram of more speed.. both will work at 333 mhz only... btw DDR ram is very rare and will be costly... you will be better buying 2 DDR2 512MB sticks for good speed... _ |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| SE user guide or useless guide, wat u say. | Destruction | Mobiles and Tablets | 8 | 21-03-2007 09:41 AM |
| Hdd Upgrade Guide? | karthik55859 | Hardware Q&A | 2 | 05-01-2007 08:25 AM |
| AMD system upgrade..err??no u all bored of upgrade forums but pls do help me...!! | karthik316_1999 | Internet & WWW | 11 | 18-07-2006 08:10 PM |
