06-04-2008, 04:32 PM
Cool as a CUCUMBAR ! ! !
External casing 4 dvd\cd rom ????
anybody using external casing 4 dvd\cd rom ????
is it similar 2 casing of hdd ?
... W H O T ...
06-04-2008, 08:17 PM
BlackBerry Guru ! :)
Re: External casing 4 dvd\cd rom ????
^ i saw it yesterday of made BenQ and was quite nice....was of 5.25" and cost was just Rs. 600/-.... u must give it a shot before buying .. wats ur current location ? Prices may vary acc. to that... i enquired in Nehru Place .
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
07-04-2008, 11:33 AM
600rs .... quite good ......
... W H O T ...
07-04-2008, 03:53 PM
08-04-2008, 05:19 PM
then if i plug-in hdd external casing with my dvd riter, will it work ?
as hardware is the same .....
... W H O T ...
08-04-2008, 05:34 PM
^ no way buddy .... HDD enclosures are of 2.5" amd 3.5" ..... whereas , the Optical Disc enclosures are of size 5.25"  ..
So better buy a new one  ..... i meant they look similar in terms of their views !
08-04-2008, 06:08 PM
Search for Adventure
I have a question on tht external casing - I bought 1 casing for my hdd - IDE to USB casing, but the encloser is too bad of tht casing, if I screw-up the casing it is unable to recnize the drive while if I keep it open just conecting the ports it works ( but not very good, sometimes it miss the hdd).
Would u give me any solution for that?
Nobody is Perfect. I am "Nobody"
08-04-2008, 07:50 PM
^ u better get the enclosure exchanged if its of small size .. make sure have r having 3.5" enclosure for ur internal hdd instead of the 2.5" one
09-04-2008, 04:22 PM
@BBThumbHealer ..... got it ..... it was just a thought .....
hmmm .... will get a new 1 4 dvd drive .... as i have 2 carry from place 2 place ....
... W H O T ...
09-04-2008, 06:32 PM
Maybe I am a bit late but why don't you try a IDE/USB converter like this ? I have been using one with my DVD writer for about a year now...cost me around Rs. 300 at that time  I have burned hundreds of DVDs since then ...not a single failure till now
09-04-2008, 06:58 PM
Point Blanc
really good option, but I sould tell you externally used devices go bad mostly due to power supply, if the power cord is removed abruptly.
10-04-2008, 10:48 AM
Point noted...but why would the power cord be removed abruptly ?  Like I said I faced no problem during last one year
10-04-2008, 12:29 PM
@royal ..... nice option .....
... W H O T ...
11-04-2008, 04:49 AM
Point Blanc
Well, I see one interesting thing.
LG GSA-E60L priced Rs1999 in Tata Star Bazzar.
I have been looking for external writers, by putting into casing.
Here in bangalore, S.P. Road, I see the older model GSA-E40L is available and they price it around 3K.
Also, any DVD writer + casing would cost around 2K only
Damn star bazzar people should have put atleast a sony external writer
I would be real happy if anyone can suggest me on this. Guys need assistance.
Can anyone give any comparision about LG GSA H55N, against Samsung Sh203 or any Sony writer.
Ok, I forgot to add, there is one liteon also available priced 1850 in S.P road.
11-04-2008, 05:56 AM
liteon??
i mean model...?
mostly liteon r d best......
11-04-2008, 12:35 PM
get a sony 1 .... prices have fallen 2 1200rs 4 internal .... checkout with some shops ....
... W H O T ...
14-04-2008, 04:31 PM
ppl tried that usb 2 ide cable ??
can v get ONLY this cable without that power wire ?
... W H O T ...
