| Forum |
#1 (permalink) |
The250 GB is behaving strangely. I t shows up on the BIOS and Device manager but does not show on My Computer.I have so far Reloaded Windows XP sp2 on the 160GB Run Sea tools for Windows on the 250GB it has failed both the short and long drive self test. Run the Seatools DOS on the 250GB and it has passed both the short and long drive self tests without a hitch???? My technician say Format the Drive and Kiss all the Data Goodbye Result so far I cannot access my DATA Suggestions and advice welcome |
#2 (permalink) |
The Thread Killer >:)
Use a data recovery software like Active Partition recovery and try to backup as much as possible. Format and/or partition the drive. Might help.
Want to make this world a better place? Then, start seeding and don't be just a leecher |
#4 (permalink) |
Cool as a CUCUMBAR ! ! !
imo, problem with OS on ur 160gb not with hdd 250GB .....
* try running new hardware [sounds foolish bt] ....... * check connection with 250gb drive [loose 1`s] ..... ps: before formating it try @ ur frds\neighbours place ......
... W H O T ... |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Very Very Strange Problem......... | dikudik | QnA (read only) | 5 | 10-04-2007 08:17 PM |
| Strange Help Needed | codename_romeo | Hardware Q&A | 7 | 03-12-2006 11:18 PM |
| Help needed urgently!! My Computer behaving strange | Arun Kumar | QnA (read only) | 11 | 16-07-2006 02:56 PM |
| Strange USB problem ... | _timbuktoo | Peripherals | 3 | 18-06-2005 11:45 PM |
| Strange! very strange..!! Where is the Problem ? | Ricky | QnA (read only) | 8 | 11-04-2005 04:14 PM |
