Old 05-04-2008, 05:18 PM   #1 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
Unhappy Big SATA DVD-Writer Problem
Hello Guys,
I m having the AsRock 915 GL Motherboard... i got for myself a Samsung 20X SATA DVD-Writer With Octoedge ( SH-S203 ) today....
Now when i plug that onto my mobo and power up the computer , the PC starts displaying vertical and horizontal white lines , and i m just stuck at the POST...also , i am unable to access my BIOS at that time ! Therefore , i have to perform a direct switch off ! ( Even Ctrl+Del+Alt doesn't work ! )
There's no issue of power as the same problem persists even when i disconnect my HDD and Other DVD-Writer !
What can be the problem ? Is the motherboard having conflict with the Writer ?
As Soon as i disconnect the Writer , PC Works fine alongwith the display !
Thnx & Regards ,
BBThumbHealer
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
BBThumbHealer is offline
Old 05-04-2008, 08:08 PM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: Big SATA DVD-Writer Problem
the dvd writer could be the culprit. But also try fitting that dvd writer on mobo's different sata port.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 05-04-2008, 09:47 PM   #3 (permalink)
Tried on evry port but same result....shud i then exchange it for IDE one ?
Still waiting for solutions....
Old 07-04-2008, 12:04 AM   #4 (permalink)
I M A *STAR*
saqib_khan's Avatar
Don't exchange it for another pata, instead exchange it for sata only.
It should work.
Blogging at:
Technostarry
saqib_khan is offline
Old 07-04-2008, 04:58 PM   #5 (permalink)
Got it resolved finally on my own.. .. there was a conflict due to the configuration of master and slave drives...
i didn't set the jumpers right....specified both the drives as master
Sata or Pata DVD Writer to buy ... passion_unlimitedd QnA (read only) 13 14-02-2008 11:45 AM
Can I connect a SATA DVD-Writer to my ASUS Motherboard. Please Help. Yoda Hardware Q&A 1 11-11-2007 09:02 PM
Please Help Sata DVD Writer Problem!!! sandipmondal123 Hardware Q&A 2 03-10-2007 03:31 PM
Help me buy a SATA DVD writer ramu Hardware Q&A 2 03-04-2007 05:09 PM
- by tv6952
- by Charley
- by soumya
