Old 05-04-2008, 04:01 PM   #1 (permalink)
Indidiot
Plasma_Snake's Avatar
Question Customizing Keys
I've got the Logitech Keyboard Mouse combo. The keyboard is 101/102 Multimedia keyboard with PS/2 interface. Can I customize its Multimedia Keys or does it happens only on keyboards that allow customization of keys?
Plasma_Snake is offline
Old 05-04-2008, 04:54 PM   #2 (permalink)
Evolving Rapidly...
confused's Avatar
Default Re: Customizing Keys
i used to use cordless desktop combo, in which i could customize very limited no of keys ....... using set point
now i use the software to customize keys on my g7.....
http://qbitmesra.blogspot.com - Quenching BIT's Quriosity
"Female sexuality isnt a myth" - what i learnt in my first year at college
confused is offline
Old 06-04-2008, 10:02 AM   #3 (permalink)
If you got any software with this keyboard to install then you can change these settings going to control panel and selecting keyboard after installing it. You also get such option in TweakXP
ThinkFree is offline
Customizing PHPizabi debiprasad_sahoo Open Source 4 03-10-2007 06:54 PM
Customizing XP 'Autorun' & 'My Computer' adit_sen Software Q&A 6 02-10-2006 12:36 PM
Customizing taskbar adi87 QnA (read only) 5 06-03-2006 07:44 PM
"sticky keys"... literally.... (Laptop keys sticking down) mvishnu Laptops and Netbooks 5 27-02-2006 05:59 PM
customizing opera 8 dhawald Internet & WWW 2 17-06-2005 08:07 PM
