LinkBack (4) Thread Tools Display Modes
Old 05-04-2008, 11:31 AM   4 links from elsewhere to this Post. Click to view. #1 (permalink)
Unhappy Intex External usb TV tuner card TV Box 2.0
I bought above tv tuner card for use with laptop
My laptop configuration is as follows
Model: Acer 4710z laptop
processor:intel pentium dual core 1.86 ghz
160 gb hdd
1gb ram
OS windows xp sp2
I have installed tvr 2.0 from honestech which came bundled with the card
I also connected a simple tv antenna to the card
But still it does not show me TV
The TV button on the panel of tvr2.0 software does not become active
and I am not able to detect the problem
Can anybody guide me about this problem.
My e mail is sal765@gmail.com
sal765 is offline
Old 24-04-2008, 02:11 PM   #2 (permalink)
Smile Re: Intex External usb TV tuner card TV Box 2.0
160 gb hdd
1gb ram
OS windows xp sp2
Dear Member,
You have done what actually anyone would do after buying a new hardware.
1.See the resolution of your Laptop. if it is more than 1024*768 reduce it.
2.Did you buy the correct USB TV Box for Laptops?There are two categories.
3.Load the correct driver manually.
Do not use the Autorun Facility.
See if the System is set to PAL not NTSC or Secam.
I think it will work.
dsrahul is offline
Old 03-05-2008, 07:31 PM   #3 (permalink)
Default Re: Intex External usb TV tuner card TV Box 2.0
Thanks RAHUL
I checked the things as you said and able to obtain only cable tv
But my problem is now how to see Doordarshan's free TV Channels DD1 and DD news on the tvr 2.0 software
Whenever I connect cable tv CABLE to the tv box 2.0 I am able to see cable channels
But whenever I connect a simple antenna (Circuler one) to the TV box I am not able to see any free to air channels like dd 1 ddnews.
Can anybody guide me in this regard?
sal765 is offline
Old 05-05-2008, 11:06 AM   #4 (permalink)
Cool Re: Intex External usb TV tuner card TV Box 2.0
Dear Member,
To receive TV chanells from DD :
1.Use co-axial cable available in TV shops for TV(Bit xpensive)
2.Or buy a long feeder cable ,keep the antenna (Yagi type) on your roof.
connect a baloon jack(purchased from Chandni Rs.10/-) at the end of the feeder to your TV Card.
Open your software Honestech.
goto settings.
select antenna.
scan for channells.
finished. you will see all free channels working.
Rahul
dsrahul is offline
Old 11-12-2008, 10:26 AM   #5 (permalink)
Hi
I am staying in Noida(Delhi)
I have the same TV tuner box , It is working with vista but my problem is it is not able to get all cahnnels , The cable here shows nearly 90 channels but the TV tuner is able to detect only 60 channels , also i am not able to see any finetune option in the TV software to tune channels manually .
Does anyone know the solution..
anup.glorious is offline
Old 15-12-2008, 10:42 AM   #6 (permalink)
Dear Anup,
The driver which you have installed is the one made for XP.
The driver which is required for your system is different.
I am attaching a driver for your system, Download this & extract it to a folder then uninstall the earlier driver ,then restart the computer while prompted install fro the location where you saved this files.
Rahul
Any problem let me know.
dsrahul is offline
Old 22-12-2008, 12:22 PM   #7 (permalink)
Hi Rahul
Thanks for the reply ,
But I was able to solve the problem , the problem was I selected the option T.V insteda of CATV in the settings , When I selected option CATV & scanned the channels again I was able to get all the channels .
-Anup
Old 07-03-2009, 10:30 PM   #8 (permalink)
Originally Posted by anup.glorious View Post
Hi
I have the same problem that anup.glorious I have windows vista and the tv turner box it doesn't work correctly. Could any body help me please?
polla7 is offline
Old 07-03-2009, 11:11 PM   #9 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
read the post above yours...he has mentioned the solution
गीक होना माँगता
victor_rambo is offline
Old 07-03-2009, 11:38 PM   #10 (permalink)
I saw the answer from dsrhaul but I'm new here and I don't know where I can found the driver for my computer that's what I'm asking. Thanks again
polla7 is offline
Old 06-05-2009, 10:55 PM   #11 (permalink)
Dear drahul,
can you send me the driver for INTEX USB 2.0 TV Box as the CD which i got with this does not have the correct driver.. plzzzzzzzzz help me.. need this drivers
Rohank is offline
Old 07-05-2009, 10:59 AM   #12 (permalink)
off topic...how is the quality of the channels? and are you able to record TV content?
izzikio_rage is offline
Old 11-05-2009, 05:09 PM   #13 (permalink)
Hello friends ,
Why are you worried about drivers there is a site for the whole drivers search there
dsrahul is offline
Old 04-01-2010, 08:33 PM   #14 (permalink)
Good to be among u all..
dubey.vibhu's Avatar
Default Which external TV tuner box(CRT & LCD) is best under 1000 rupees?
dubey.vibhu is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/84475-intex-external-usb-tv-tuner-card-tv-box-2-0-a.html
Thread Intex Tv Tuner On Ubuntu !!!! | Digit Forum | BoardReader This thread Refback 20-05-2011 08:11 PM
Usb Tv Tb240fm | SukaKita.com This thread Refback 30-11-2010 01:03 AM
Intex Model It Tb240fm | SukaKita.com This thread Refback 27-11-2010 12:07 AM
Intex External usb TV tuner card TV Box 2.0 - Digit Technology ... - ZapaFly This thread Refback 13-11-2010 09:24 PM
INTEX TV tuner card jambay19 QnA (read only) 9 15-12-2008 03:05 PM
Help Buying External TV Tuner card Ganeshkumar QnA (read only) 2 02-12-2007 06:25 PM
