Old 05-04-2008, 05:30 AM   #1 (permalink)
Question 896 MB RAM possible?
Hi,
When you right-click on the My Computer icon on the desktop and select properties; in the system properties, it is given as follows:
Microsoft Windows XP
Professional
Version 2002
Service Pack 2
<name of user>
Intel (R)
Pentium (R) 4 CPU 3.00 GHz
3.00 GHz, 896 MB of Ram
Physical Address Extension
Now, what is this 896 MB of RAM; I had asked for 1 GB RAM. And what is Physical Address Extension?
Thanx.
HydraHeaded is offline
Old 05-04-2008, 05:53 AM   #2 (permalink)
Default Re: 896 MB RAM possible?
Hi HydraHeaded,
Thats normal!
Your computer is sharing your rest of the RAM for your display.
896MB + 128MB = 1024MB
Cheers,
Ace Ventura
Ace Ventura is offline
Old 05-04-2008, 08:19 PM   #3 (permalink)
Fast 'N' Furious
topgear's Avatar
^ +1
http://en.wikipedia.org/wiki/Physical_Address_Extension
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 05-04-2008, 08:22 PM   #4 (permalink)
Dreamweaver
Gigacore's Avatar
you can disable it from your BIOS
Gigacore is offline
Old 07-04-2008, 07:35 PM   #5 (permalink)
Fast 'N' Furious
topgear's Avatar
^ You can disable it using windows itself. I've posted a tutorial it about here :
How To Disable Data Execution Prevention aka DEP
But it seems like no one is interested
topgear is offline
Old 07-04-2008, 07:50 PM   #6 (permalink)
ancientrites's Avatar
HydraHeaded
if u wanna see 1gb then u will have to buy and install graphic card depending upon your mobo if its agp or pcie.
asus psn32-e sli,1x4 ddr2 ram,nvidia stacker case,19inch lcd,sapphire hd4850 graphic card,smps 730 w from zeb
ancientrites is offline
