| Forum |
#1 (permalink) |
I have an old pc bought in 2005. The config is celeron 1.7 ghz, 512 Mb ram and some mercury motherboard. I don't remember the motherboard specs. The motherboard has built in usb 1.1 (or 1.0?) support. Duw to this my new usb pen drives work extremely slow on this m/c. Is there any way to enable the usb 2.0 support on the motherboard? Whether the firmware flashing will help? Thanks and Regards, Amit. |
#2 (permalink) |
Fast 'N' Furious
Just buy an usb ( 2.0) pci add on card. That will solve your prob.
Also firmware flashing will not help
ToPsPeEeD = FaSt BuT StEaDy AMD Radeon HD 6850 OverClocked to 1 Ghz !!! Blog : http://topgeartopspeed.wordpress.com/ ---------------------------------------------------- Never buy viewsonic products : http://tinyurl.com/ykwx4oa |
#4 (permalink) |
OK. Thanks a lot for your replies.
Can you tell me the price of the same? Also whether using this card is as good as using the usb 2.0 port or are there any other implications as far as transfer rates are concerned? Regards, Amit. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Will my motherboard support GeForce 8600GT | arun77574 | Hardware Q&A | 23 | 09-09-2007 03:37 PM |
| Will Mercury 845GL motherboard support 512MB DDR RAM AT 333/400 MHZ | jiteshbhimani | Hardware Q&A | 8 | 07-07-2007 08:59 PM |
| motherboard with good grafix support | bkpeerless | Hardware Q&A | 5 | 03-02-2007 11:01 AM |
| Motherboard Support for Storage Capacity | techtronic | Hardware Q&A | 1 | 23-06-2006 01:29 PM |
