Old 02-04-2008, 08:25 PM   #1 (permalink)
Mobile Freak
reddick's Avatar
Smile Suggest an Wi-Fi router
Hello Bro!
I have an basic pc with following config:
AMD 2000+ XP
ASUS Mobo
512MB RAM
40 GB HDD
Sony DVD Writer
No graphics card
WinXP Pro as OS
I wana wi-fi router for my system.I don't know much about how wi-fi works,it's qualities,about range,etc. Please provide some info regarding wi-fi routers.
Also suggest me an average router but of best quality I wana use it for net surfing only
THANKS ANYWAYS
Hope 4 d best n Do d right :)
reddick is offline
Old 02-04-2008, 09:18 PM   #2 (permalink)
The High 5 Flyer
sam9s's Avatar
Default Re: Suggest an Wi-Fi router
Just out of curiosity, why do you need a router if you have a desktop, are you gonna use it as a DSL modem or your desktop PC would mostly be mobile?
Neeway I recently bought a Router for my Laptop. It Linksys WRT54G. And I have been using it 24x7 for the past 15 days without any glitch. Configuring it needs some tech know how if it has to be used with existing DSL Modem. Got it for 2100 INR Delhi NP Price as on March 2008.
sam9s is offline
Old 02-04-2008, 09:52 PM   #3 (permalink)
=--=l33t=--=
ring_wraith's Avatar
Sam is right. There is no point of a wi-fi router it you don't have a Laptop/PSP/other device that has wi-fi.
+1 for the linksys though.
Homer: God bless those pagans.
ring_wraith is offline
Old 02-04-2008, 10:26 PM   #4 (permalink)
anand1's Avatar
Yes i do suggest for Linksys for specifications and model visit its official site. Serach it out with Google Uncle.
Technology On The Fly
anand1 is offline
Old 03-04-2008, 09:39 PM   #5 (permalink)
Mobile Freak
reddick's Avatar
I have heared abt D-Link also
Plz explore ur replies
I just wana surf net via router
It may b upto 2K only
Thanks Again...
reddick is offline
Old 03-04-2008, 10:09 PM   #6 (permalink)
The High 5 Flyer
sam9s's Avatar
Thanks Again...
If net surfing is the only purpose then go for a DSL Modem, router is usually for making a wifi, though it can be used as a DSL Modem or hub/switch as well but why wast money when all you need to do is surf. You dont even have to actually buy a DSL modem, your ISP should provide you with one on rental basis or if you wanna keep it you might buy it as well. It would cost you much less then a Router.
Also D-Link is not know for its quality. After Linksys I'd prefer Netgear......
sam9s is offline
Old 03-04-2008, 10:16 PM   #7 (permalink)
a_g = JPKN
s18000rpm's Avatar
if in future you're gonna buy a laptop, then only get a wifi router.
i'd suggest Netgear.
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 05-04-2008, 12:32 PM   #8 (permalink)
Mobile Freak
reddick's Avatar
Actually I live in hostel n the admin. has just bring Wi-Fi in our campus.So all guys having Lappy surf net whole night...I also wana use net...That's why I'm asking for router only which gives me relative speed!
reddick is offline
Old 05-04-2008, 01:23 PM   #9 (permalink)
a_g = JPKN
s18000rpm's Avatar
then what you need is a PCI wi-fi card & not a router
like this one
Old 07-04-2008, 07:42 PM   #10 (permalink)
Mobile Freak
reddick's Avatar
OK
I have ASUS Mobo with AGP Slot
Which wi-fi card is compatiable with it
reddick is offline
Old 07-04-2008, 07:50 PM   #11 (permalink)
TechTin.com
ravi_9793's Avatar
r u planing to use DSL internet on this card??
If yes..than prefer Modem-cum wifi router.
ravi_9793 is offline
Old 08-04-2008, 12:12 AM   #12 (permalink)
The High 5 Flyer
sam9s's Avatar
like this one
yep rpm is right, you need a wifi card not a router, BTW which ASUS mobo do you have..........
sam9s is offline
Old 16-04-2008, 05:46 PM   #13 (permalink)
Mobile Freak
reddick's Avatar
Cool Re: Suggest an Wi-Fi router
I don't know the exact name but it has 'AGP 8x slot'
Plz tell me which wi-fi card will work on it
Mention d company and model name also including it's cost
Thanks Anyways!
reddick is offline
Old 17-04-2008, 06:33 PM   #14 (permalink)
Mobile Freak
reddick's Avatar
Exclamation Re: Suggest an Wi-Fi router
AnyOne
reddick is offline
Old 17-04-2008, 06:53 PM   #15 (permalink)
AGP slot is for Graphics cards........
You should have an empty PCI slot.....
Anyways, I'll suggest you to go for a Netgear Wifi PCI card......http://www.netgear.com/Products/Adap...ers/WG311.aspx
You'll get it for Rs.800~....
ico is offline
Old 18-04-2008, 12:48 PM   #16 (permalink)
Mobile Freak
reddick's Avatar
Thumbs down Re: Suggest an Wi-Fi router
Thanks Gagan 4 d link!
But that gudget demands 'PCI 2.2' slot but I only have AGP slot
So that mean this card is not compatiable with my PC
Wht's d solution than...May b I have 2 change my mobo or wht...
reddick is offline
Old 18-04-2008, 05:19 PM   #17 (permalink)
^^ Man, you'll be definitely having an empty PCI slot.....
Anyways, USB to Wifi cards are also available. But I'm damn sure that you've a PCI slot. Just check your Mobo.
Get this: http://www.netgear.com/Products/Adap...ers/WG111.aspx Its just Rs.100~ expensive than that PCI and actually far better. You can also use it with laptops lacking Wifi.
ico is offline
Old 18-04-2008, 07:34 PM   #18 (permalink)
a_g = JPKN
s18000rpm's Avatar
100buks?
my cous. bought this for ~Rs.1000
Old 19-04-2008, 12:35 AM   #19 (permalink)
Let there be music.....
sashijoseph is offline
Old 19-04-2008, 12:41 AM   #20 (permalink)
a_g = JPKN
s18000rpm's Avatar
oops
Old 19-04-2008, 08:01 PM   #21 (permalink)
Mobile Freak
reddick's Avatar
OK than I gona check my mobo 4 PCI slot n try it later...Thx Buddy!
reddick is offline
Suggest router for MTNL broadband ssdivisiongermany1933 Hardware Q&A 2 17-02-2008 08:31 PM
Router for Mac/PC d Networking 1 23-09-2007 05:07 PM
Reliance Router Info?, Does anybody know which router does Reliance uses? mib2_007 Networking 1 25-01-2007 10:52 PM
Router shyamno Software Q&A 2 24-06-2006 01:16 PM
- by c4u
