Old 01-04-2008, 03:35 PM   #1 (permalink)
darklord's Avatar
Wink Very Simple Fan mod for Gigabyte 8660GT
Did this for a friend,
thought of sharing,maybe it will be useful for folks here,especially with summer already upon us
This is a passive card and can get pretty hot while gaming.
More here - Easy & Simple fan mod for graphic card
Thanks !
Amey
Team THL
darklord is offline
Old 01-04-2008, 04:10 PM   #2 (permalink)
Cool G5's Avatar
Default Re: Very Simple Fan mod for Gigabyte 8660GT
Bringing more fans does not necessarily means improved cooling.It depends upon the placement of the fans.Also upon the location of various other components inside your cabinet.
Your mod is very amateur.
It's like adding extra fan to your cabinet.
Thanks anyways.
Can you tell me the temp drop after doing this?
Cool G5 is offline
Old 01-04-2008, 05:33 PM   #3 (permalink)
darklord's Avatar
Bringing more fans does not necessarily means improved cooling --- Agreed, but then earlier there was not even a single fan
It depends upon the placement of the fans ---------> Think of a better place to place the fans on the card ?
Also upon the location of various other components inside your cabinet.----> Care to elaborate ?
Your mod is very amateur. -------> Never said it was scientific breakthrough
It's like adding extra fan to your cabinet.-----> How is that so ? Isnt the fan blowing air directly over the Heatsink ?
Can you tell me the temp drop after doing this? -------> If you read the first post, you wouldnt have asked that question, This was done for a friend,its not my card.
darklord is offline
Old 02-04-2008, 01:45 AM   #4 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Yes a fan blowing directly toward the gfx card (from below) does bring down the temps. Its a much better option than the side panel fan blowing towards the gpu.
I have done it and the idle temps for my 7950GT has come down to 47c from 55c and the load are around 58c from 65c.
john_the_ultimate is offline
Old 02-04-2008, 02:38 AM   #5 (permalink)
At Hell's Disq
hellgate's Avatar
another fan setup which i use to cool my **))GTS is possible only with dual slot cooler cards.in this mod,u need to remove all the xcabinet back plates whihc guard the expansion slots.
now u need to place a 80mm or 92mm fan just below the dvi ports in such a way that part of the fan is in level with the gfx crad exhaust holes (the gaps below the dvi ports in a dual slot cooler).the fan sud be so directed that it blows air away from the card.
temps drop by bout 5-7c.
hellgate is offline
MSI or ASUS or GIGABYTE debasish13 Hardware Q&A 6 24-11-2006 08:04 PM
MSI or Gigabyte ondemandemails Hardware Q&A 7 24-07-2006 09:55 AM
Asus vs Gigabyte sAr QnA (read only) 12 30-10-2004 08:33 PM
- by c4u
