Old 01-04-2008, 10:35 AM   #1 (permalink)
Don Draper is coming back
vamsi_krishna's Avatar
Default please answer....
hello ,
i have transcend jetflash v110 4gb pendrive. when iam syncing my friend's mp3 collection with my pendrive. it showed me a error that the pen drive is write portected. any suggestions, beyond the follwing. because i have tried all these thigs stated below.
1) format using system management( right clicking on 'my computer' and chooseing 'manage'.
2) weather to chek the write portection switch on the stick( there is'nt such thing)
3) try to format in you friend's system( because it showed the same error)\\
4) try formating using windows xp installer ( it shows an error tooo...)
5) try formatting in linux( i had tried in neraly 20 linux versions but all of them will be formated in linux. But when i plug that in windows it shows all the files and the same error)
6) try using hp removable disc fromat tool(it too shows the same error)
7) to throw off my one( because i cann't)
8) to return to vendor for replacement because it is out of warrenty.
if any one have ideas beyond the above. If you suggest me . it will be more than appreciation
vamsi_krishna is offline
Old 01-04-2008, 11:58 AM   #2 (permalink)
Mad and Furious
redhat's Avatar
Default Re: please answer....
This happened onlly on ur friends computer right??
On his computer...
Go to start -> Run -> Type "regedit"
Here go to:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Con trol\StorageDevicePolicies\
set value of "WriteProtect" to 0
My new Tech Blog : http://technewspaper.blogspot.com/
redhat is offline
Answer this plz Chirag Chit-Chat 9 27-12-2007 03:56 PM
Try answer this one blackpearl Chit-Chat 24 16-07-2007 10:21 AM
To get answer suraj QnA (read only) 3 09-12-2006 10:26 AM
answer this????? Binay 007 Gamerz 3 29-11-2006 05:54 AM
Please Answer............ nipun_the_gr8 QnA (read only) 4 22-04-2005 05:31 PM
- by c4u
