Old 31-03-2008, 07:54 PM   #1 (permalink)
pratik03's Avatar
Default 24 pin Motherboard & 20 pin PSU
I am using motherboard having 24 pin power connector & PCI-e Solt but without graphic card.
2 months before my PSU starts malfunctioning so i replaced it with my older PSU which is 7 Year old & has only 20 pin power connector (I heard somewhere that additional 4pin are used for pci-e gfx card) , & now pc is working fine.
I just want know that is this safe ? or it will damage my motherboard, i am going to install new gfx card & PSU next week.
pratik03 is offline
Old 31-03-2008, 09:47 PM   #2 (permalink)
pratik03's Avatar
Default Re: 24 pin Motherboard & 20 pin PSU
seems no one knows secret of extra 4 pins
pratik03 is offline
Old 31-03-2008, 11:08 PM   #3 (permalink)
dOm1naTOr's Avatar
ya, it ll work fine
some of my friends are using A8N VM mobo with 20 pin connector.
But if u gonna use any PCIE 16X cardk, ull need to connect a 24pin PSU.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 01-04-2008, 01:25 PM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
Man get a new 24 pin smps ASAP
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 01-04-2008, 08:24 PM   #5 (permalink)
dOm1naTOr's Avatar
Zebronics 400W PSU is a gud buy @ 400 bucks. Better than most others at same price range.
G3: XPS M1530 |
FZ 16.
Old 01-04-2008, 08:51 PM   #6 (permalink)
pratik03's Avatar
I am going to replace my older PSU in next week with new one 24Pin PSU & also adding new gfx card.
what i want to know is my mobo in a good condition ? or there is already some damage done in PCI-e section which run on that extra 4 pin power supply, because i am using it with 20 pin psu for more than 2-3 months.
It is very important to know this before buying gfx card
pratik03 is offline
Old 01-04-2008, 11:31 PM   #7 (permalink)
GeekyBoy's Avatar
I'm using a 20 pin psu with an ASUS A8N VM for the past 1.8 years and having no problem whatsoever !
Intel Core i3 2100 //4GB Corsair DDR3 1333 RAM //Intel DH61WW//Sony AD-7260S DVD-RW//Samsung 2033SW Monitor//Windows 7//Seagate ST3250310AS 250GB HDD
GeekyBoy is offline
Old 02-04-2008, 05:56 AM   #8 (permalink)
Fast 'N' Furious
topgear's Avatar
@, pratik03 - I think there shouldn't be any kind of probs
topgear is offline
Which Motherboard is this......? satyamy Hardware Q&A 4 06-05-2007 05:59 PM
help me on my motherboard sathyan1987 CPU / Motherboards 2 07-06-2006 12:35 PM
*******Motherboard******* digitizen Hardware Q&A 6 23-11-2005 09:37 PM
how to look which motherboard shivi4 CPU / Motherboards 2 31-07-2005 01:01 AM
Motherboard doom_marine CPU / Motherboards 2 04-07-2005 11:52 AM
- by c4u
