Old 31-03-2008, 12:14 PM   #1 (permalink)
Fullbring
Zangetsu's Avatar
Question Display Resolutions
I know dat games @ high resol looks gr8....
But I wanna know dat whether it depends only on G-Card & monitor
or only on G-Card ?
coz I have LG CRT monitor 700S if i upgrade my system except monitor
will it support high resolutions?
pls dont laugh Im getting my doubts cleared...
Zangetsu is offline
Old 31-03-2008, 01:29 PM   #2 (permalink)
At Hell's Disq
hellgate's Avatar
Default Re: Display Resolutions
the max res that u can game depends both on ur gpu and ur monitor.
wit ur present monitor (700S) u wont be able to game @ res higher than 1280x1024 cuz thats the max res supported by ur monitor.every monitor has a max res that they r capable of displaying.so choose ur monitor and gfx card in accordance with the res at whihc u plan to game.
hellgate is offline
Old 31-03-2008, 01:49 PM   #3 (permalink)
Fullbring
Zangetsu's Avatar
Alryt..........then which r the latest models of monitors TFT/LCD which
supports dat much res0lution ?
Zangetsu is offline
Old 31-03-2008, 02:20 PM   #4 (permalink)
At Hell's Disq
hellgate's Avatar
if u want max res of 1280x1024 from TFT then buy 17" or 19" (non widescreen).
but its better to buy 17" or 19" wide with a res of 1440x900
hellgate is offline
Old 31-03-2008, 09:58 PM   #5 (permalink)
mayanksharma's Avatar
Choices may vary. Though, not many prefers widescreen for gaming. However, they are gr8 for movies.
mayanksharma is offline
Old 31-03-2008, 11:21 PM   #6 (permalink)
dOm1naTOr's Avatar
Most older games looked weired on widescreens, but most of 2days games gud supports for wide monitors. Even classical games like CS 1.6 has patches to use widescreens with them.
@ 1440*900, a 17" monitor will have crisper nd sharper images than a 19".
And for playing most games @ 1440*900 with med ~high details u ll need min of 8600GT nd better get a 9600GT/HD 3870.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 01-04-2008, 09:46 AM   #7 (permalink)
The Frozen Nova
casanova's Avatar
And most of the times, its our monitors that limit display resolution as they are not upgraded that often.
www.nerdweed.blogspot.com
casanova is offline
Old 02-04-2008, 12:27 PM   #8 (permalink)
Fullbring
Zangetsu's Avatar
But if I want 2 play only @1024*768 with all eye-candy turned on..will
buying a budget G-Card do such as 8600GT
Zangetsu is offline
Old 02-04-2008, 12:43 PM   #9 (permalink)
hell boy
u cant even turn on all eye candy and effects at 1024x768with 8600gt even en8600gt finds it difficult to run crysis at 1280x1024 with everything set to high....!!!!
like sly stallone i am bringing the pain the only difference is that i got SINGH in my name..,!!
MasterMinds is offline
Old 02-04-2008, 01:18 PM   #10 (permalink)
Fullbring
Zangetsu's Avatar
So I assume dat above high settings is reachable in 8800GT AD edition or 9600GT
then can 8600GT is enough 4 playin crysis in medium settings(with 1024*768)
it doesnt look dat weired(graphics) in medium settings I guess...
it looks nice in medium settings.......
since ATi & Nvidia are following moore's law
so how much price drop will be there in 8800GT ADE & 9600GT in 1 or 2 yrs
I guess they will be in our budgets....
Zangetsu is offline
Old 02-04-2008, 07:11 PM   #11 (permalink)
First of all, dont get confused between High/Above High/Ultra high settings.
And yes, can be achieved easily with 8800GT. For, 9600GT cant say. I think, it struggles. May be 9600GT owners can shed more light.
Ofcourse ! And if ur card can, then u can play Crysis at high settings, no AA @25+ fps. Just like me...
8600GT can be a very good card, if u want it to be. Nevertheless, the card is best known for VFM.
Old 03-04-2008, 11:03 AM   #12 (permalink)
Fullbring
Zangetsu's Avatar
so who r the 9600GT's owners pls reply
What do u mean by "can" do I have 2 overclock it.....
I 've found one user using 9600GT he can answer my query ....
"ionicsachin" has 9600GT card he knows pretty well
Zangetsu is offline
Pen drive corrupted ! any resolutions ? sankaranand Hardware Q&A 10 01-01-2008 10:29 PM
Your New Year Resolutions for 2008 sourav123 Chit-Chat 19 26-12-2007 10:47 AM
New Year Resolutions. din Chit-Chat 27 18-12-2007 09:50 PM
- by c4u
