Old 28-03-2008, 05:33 PM   #1 (permalink)
Stalker's Avatar
Question Suggest a 5.1 Headset
Hi guys,
have decided to buy a 5.1 headset. I had narrowed it down to the Zalman 5.1 Headset Or the Gainward SoundXplosion, but they arent available in India.
BUDGET: ~ 3K-4K
Plz suggest a 5.1 Headset, which is available in India.
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 28-03-2008, 11:07 PM   #2 (permalink)
mayanksharma's Avatar
Default Re: Suggest a 5.1 Headset
well there was a time when i bought iball i-850mvi headphones. They sound awesome. Plus, the vibration of the dome during bass reproduction is an advantage for sure!
Ok, during that time, i came to know about this I-Ball 5.1 headset. The pins are gold plated and they sound nice. I am sorry, i really dont remember the model. Try enquiring about it. As soon as i get to know about them, i'll post the model.
mayanksharma is offline
ipod headset vs nokia hs-28 headset dead Mobiles and Tablets 8 07-02-2008 05:12 PM
Suggest Nokia Headset raptorz Buying Advice 2 07-10-2007 02:54 AM
Which headset is this? REY619 Mobiles and Tablets 6 29-08-2007 05:08 PM
Which BT headset do you own? ksundar Mobiles and Tablets 3 30-01-2007 05:04 PM
Suggest a BT headset gdatuk Buying Advice 2 07-05-2006 11:31 AM
- by c4u
