Old 28-03-2008, 11:48 AM   #1 (permalink)
Default External USB HDD problem
I have P-III 800/180e Mboard/256MB/160GB HDD/DVD Combo/450W SMPS
2 ports USB (Non 2.0)
OS is Win-XP (SP2). I have recently purchased Seagate-80 GB USB HDD which is not getting detected. I have also tried installing a PCI to USB (4 port hub) but still it is not detected.
However all USB pen drives work OK.
But this works fine on another PC
Kindly troubleshoot.
regards,
Mukund
mukundpande is offline
Old 03-04-2008, 12:30 PM   #2 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Re: External USB HDD problem
1st try add new hardware .......
or else open control panel >> admin tools >> computer management ......
... W H O T ...
ax3 is offline
Old 03-04-2008, 02:45 PM   #3 (permalink)
PhotonAttack
DigitalDude's Avatar
external HDDs require more power than USB flash drives so they wont work in the USB ports that are in the front of the PC (cos they are low power)..
this is what I know.... see what you can do with this info
_
DigitalDude is offline
Old 05-04-2008, 01:34 PM   #4 (permalink)
ax3
ax3's Avatar
@mukundpande ...... is it working ? do update us .......
... W H O T ...
ax3 is offline
External harddisk problem-the generic volume cannot be stopped bcoz a program..... tango_cash Hardware Q&A 2 27-09-2007 11:19 PM
120 GB external hardisk problem. uergent pls help!! legolas QnA (read only) 4 10-01-2007 06:10 PM
Problem with 320 GB external HDD srimaya_rath Software Q&A 10 03-01-2007 06:09 PM
external modem problem help zuala77 Hardware Q&A 1 22-01-2006 10:23 PM
- by c4u
