Old 28-03-2008, 09:59 AM   #1 (permalink)
Hostage Negotiator
nithinmohantk's Avatar
Default VisionTek Radeon 3870 and Crysis
Dear Friends;
I have a very strange problem with VisionTek Radeon 3870 512MB DDR4 and Crysis.
My System Config is
Procy: AMD Athlon 64 3800+ (Venice Core) - 89W
Mobo: MSI K8NGM2-L
GPU : Visiontek Radeon 3870 512 DDR4
PSU : Corsair VX 450 (offering around 86% efficiency)
HDD's: 2x Seagate SATA II 250GB, 1x Seagate SATA II 750GB, 80 GB Seagate IDE 7200 RPM(using this only for torrent downloads, because i don't want to harm my other HDD's because of continous Read/Write of Torrents)
DVD ROM: Sony
DVDWriter: Samsung SATA DVD Writer
Cabinet : Zebronics Rage
Cooling Fan: one 300mm+ intake fan on the side LED
one 120mm Exhaust on rear LED
one 120mm Exhaust on front LED
one 80 mm Intake (for Harddisk's cooling)
I came to know that Corsair VX 450 can handle this much load.
I'm getting very poor graphics on Crysis, even my friends who are using NVidia 8600GT and getting better graphics than me. Could you please tell me whether this is a Bug or is there any fix available for Catalyst 8.3..
I'm getting poor Terrain and Black out in most of the Screen Display Areas, in the beginning of the game Crysis itself. Even i'm not able to see a single Frame properly, I don't what is the problem. I uninstalled the Drivers and tried again.. Still things are the same..
I don't know whether it's a power supply problem..
But for other games Quake 4, Max Payne 2, NFS Carbon, Unreal T 3 it's giving me the performance that it can deliver.. So i think this could not be the power supply problem..
I saw an ATI HotFix pack for Crysis based on Catalyst 7.xx, but i thought this might have been fixed with 8.xx versions..
Please help me to a solution at the earliest.
Hostage Negotiator
You are surrounded by simple, obvious solutions that can dramatically increase your income, power, influence and success. The problem is, you just don't see them.
nithinmohantk is offline
Old 28-03-2008, 10:11 AM   #2 (permalink)
Default Re: VisionTek Radeon 3870 and Crysis
What drivers are u using? Use latest driver Catalyst 8.3. Download the patch from www.ati.com. Performance will definitely improve.
Also installing new patch for the game can also help. I dont know the patch version. But somebody else will definitely help you out regarding this matter.
DOTA is really addictive :D
BULLZI is offline
Old 28-03-2008, 11:25 AM   #3 (permalink)
Hostage Negotiator
I used the Crysis Patch 1.2 and ATI Driver Patch for Crysis which based on Catalyst 7.xx and Also i Tried Catalyst 8.3 and Xtreme-G Catalyst 8.3(Tweaked version of Catalyst 8.3 from XTreme-G) and Radeon Omega Drivers also.. nothing does much..
ATI Catalyst Crysis Hotfix Display Driver for Windows XP / Vista
http://www.techspot.com/drivers/driv...ormation/9791/
Hostage Negotiator
Old 28-03-2008, 11:35 AM   #4 (permalink)
Then I think ur proccy is being bottleneck with the gfx card. Try overclocking ur proccy and then see if performance improves or not.
BULLZI is offline
Old 28-03-2008, 02:18 PM   #5 (permalink)
Hostage Negotiator
I Believe this could n't be the problem.. Any other suggestions please..
Hostage Negotiator
Old 28-03-2008, 03:17 PM   #6 (permalink)
deathvirus_me's Avatar
U patched Crysis ?? I mean , running catalyst 8.3 with Crysis v ?? .. v1.2 is definitely recommended ..
deathvirus_me is offline
Old 28-03-2008, 03:45 PM   #7 (permalink)
At Hell's Disq
hellgate's Avatar
the procy is surely a bottleneck in this case.oc the procy.
hellgate is offline
Old 28-03-2008, 06:01 PM   #8 (permalink)
Hostage Negotiator
Yes I Patched with 1.2 and Catalyst 8.3..
Today i got a HotFix from ATI.AMD..
Let me check whether it solves the problem..
But Hellgate i don't think this is the problem with Procy. Because all other games and even Graphics intensive games other than CRYSIS are working fine... This is a point..
Anyway i'm not much good in hardware.. please advice...
My System Config Available at..
http://dreamworksindia.no-ip.org
Please Advice...
Hostage Negotiator
Last edited by nithinmohantk; 28-03-2008 at 06:01 PM. Reason: Automerged Doublepost
Old 28-03-2008, 06:07 PM   #9 (permalink)
At Hell's Disq
hellgate's Avatar
Please Advice...
Crysis is a very demanding game.its not only gfx intensive but also physics intensive.and physics calculation is don by cpu if no dedicated physics card is present.in ur case the cpu is not able to feed enuf data to the gpu.if u can just borrow a good X2 procy like 5000+ or above and see if the prob persists.
else just oc ur present procy to 3Ghz if u can.for cards like 3870 a dual core cpu is recomended for optimum system performance.
hellgate is offline
Old 28-03-2008, 06:37 PM   #10 (permalink)
Hostage Negotiator
Thanks Buddy.. I can't go for an upgrade now. .so i'm planning to leave crysis alone...
Hostage Negotiator
VisionTek Radeon X1300 Review wnns13 Hardware Q&A 5 18-02-2008 09:23 PM
ATi Radeon 3870 and 3850 Hands-on Third Eye Technology News 10 18-11-2007 10:30 PM
VisionTek Radeon X1300 256mb PCI wnns13 Hardware Q&A 4 27-07-2007 04:00 AM
- by c4u
