Old 28-03-2008, 02:37 AM   #1 (permalink)
At Hell's Disq
hellgate's Avatar
Default laptop bricked,help needed
i've managed to brick my hp lapy while trying 2 oc the gfx card.now whenever i pwr on the lapy theres no display.it doesnt boot.only the blue lights glow.
Is there any way thru which i cud flash the lapy bios in this condition?plz help me.
hellgate is offline
Old 28-03-2008, 02:58 AM   #2 (permalink)
b_man's Avatar
Default Re: laptop bricked,help needed
...and i thought i had huge problems with my lappy...
I guess it doesn't matter whether this is still in the warranty period or not since OC voids the warranty anyway I am not an expert in all this...just telling you what i would do.
Sugg1: Get this fixed by HP service centre rather than DIY, unless you are just tinkering with it and have another lappy/desktop for the important work.
Sugg2: HP's website has a list of part-numbers (model numbers, if you will) for the replacement parts of various laptop models. Maybe you can buy/order that from HP directly.
All those who create, work against the Second Law of thermodynamics!! No wonder energy costs are so high!!
b_man is offline
Old 28-03-2008, 03:38 PM   #3 (permalink)
At Hell's Disq
hellgate's Avatar
no one else has any suggestions??
i'll give my last try 2night after i get the usb floppy drive.
hellgate is offline
Help !! I have bricked my nokia 6233 while updating firmware Edburg Mobiles and Tablets 33 26-02-2008 10:31 AM
laptop with windows xp needed raja2281 Hardware Q&A 9 11-12-2007 12:50 AM
Problem in laptop. help needed Shasta Software Q&A 2 02-08-2006 01:55 PM
help needed for an assembled laptop Rewat QnA (read only) 1 15-09-2005 05:48 PM
Laptop Review Needed!!! sumitava_b QnA (read only) 1 26-04-2005 01:38 PM
- by c4u
