my present config is:
proccy: intel p4 (2.66 GHz)
mobo: pcchips P21G (V 1.0)
RAM: 256mb ddr
H/d: 40 Gb pata
i'm not willing 2 spend much. so i'm plannin 2 buy 512 mb RAM ddr & a SATA 160 gb h/d.
will my mobo support this or do i hav 2 upgrade whole of the thing.
i use my pc only for watchin videos n downloadin.
if i buy 512 mb ram, can i use my 256 mb ram in any way.
my budget is around 3k.
end of efforts is end of life
I'll suggest you to upgrade your rig to the latest c2d based system - a complete upgrade.
you want to upgrade the old rig go for 160GB sata hdd for Rs. 1800 & with rest money go for 256 mb ram. don't forget to buy ram with same frequency only. I think 512 MB ram is enough for dowloads & watching dvd & vcd movies.
@topgear
1. if i buy a new C2D based system, then what will b the cost?
2. ya, that is my mobo.
3. my mobo has only 2 slots for RAM, if i use 2 * 256mb then in future i may hav prob, if i go 4 single 512mb stick, then i can easily upgrade upto 1 gb in future.
??? his pc is not more than 4 years old....... quite capable of d'ling/videos. where the need for a complete upgrade???
To enjoy latest games little bit & of course play HD Movie.
Originally Posted by gamemaniac
@topgear
A decent entry level PC will cost Rs. 20000 all included.
Ya, You can go for 512MB Ram. I suggest 256 MB Ram as I've thought that 256MB Ram is around Rs.1200 which you could get after buying a 160GB HDD.
he never mentioned he used his comp to play games....
Btw i read somwhere that HD videos can be played without problems with a minimum of 1.2-1.4Ghz. so again, for his needs there is no immediate need of "complete upgrade".
thanx topgear & confused.
i would love new pc config , but money is a serious constraint. now i just want my pc 2 b faster, i'll upgrade at a later stage.
