Hey frnds
my system is just 2 year old.Now whenever i try to copy some dvd or cd either my system reboots or blue screen problem arises.
So,wheather it is d problem of my sony cd drive or segate hard disk?
any solution?
plz reply..........
here is what you should do... when your computer is booting up...b4 the windows logo appears,keep pressing the f8 key... you should now have some options on screen...select disable restart on hardware failure... now resume working on your comp... now if some problem occurs you will get the blue screen for sure... now there should be a code in there.something like 0x0... note down the code and google it..u should have ur answer
