LinkBack (2) Thread Tools Display Modes
Old 25-03-2008, 11:13 AM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
shadow hunter
vivekbabbudelhi's Avatar
Exclamation MUST READ: how to make ur tvtuner work with vista MCE
a lot of people here might be interested to use EPG in MCE
here is how to make ur supporting tvtuner work with vista mce
requirements for a tuner(non hardware mpeg2 encoder) to work with vista MCE:
1. a tvtuner that has PCI AUDIO device i.e. audio is routed from PCI bus without the need of audio patch cord
& supporting driver that enables PCI AUDIO device.
almost all new tuners from pinnacle,compro,leadtek support PCI AUDIO function in hardware.What u need is drivers that enable PCI AUDIO device.
Currently almost all new drivers(vmhybrid ones) from compro enable PCI AUDIO by default on supporting compro cards.
e.g tuners like compro videomate tv gold plus 2,leadtek winfast TV2000 xp global supports PCI AUDIO.
2. a vista certified MPEG-2 software encoder
like
a.cyberlink MPEG MCE ENCODER
b.ARCSOFT MPEG ENCODER + DECODER
C.OEM ARECOFT MPEG ENCODER ONLY
D.mainconcept MPEG encoder
SETUP STEPS
1. uninstall any other PVR application like COMPRO DTV,winfast PVR,chris tv etc...
2.install mpeg2 encoder of ur choice.Make sure u install only one encoder at a time.If u want to try another one then first uninstall previos MPEG encoder..
3.install latest drivers for ur tvtuner.If ur tvtuner supports PCI audio device in hardware & drivers then only it would work with vista MCE.
now u are done just run MCE app. to check whether ur card is supported by vista MCE..
4.although vista includes its own MPEG.2 video decoder & MPEG audio decoder u may like to change it..
use this ulitity to change default decoder for vista mce.
for decoders u may install nvidia purevideo decoder,cyberlink decoder(by installing power dvd)
my experience
i was able to make my COMPRO videomate tv gold plus 2 using vmhybrid drivers & leadtek winfast tv 2000 xp global using 4.x.xx drivers to work with vista mce.
IME arcsoft OEM MPEG2 ENCODER was nice.secondly i used nvidia purevideo as video & audio decoder..
further reading
knowledge can be shared & must be BUT intelligence CAN'T be
vivekbabbudelhi is offline
Old 25-03-2008, 11:26 AM   #2 (permalink)
At Hell's Disq
hellgate's Avatar
Default Re: MUST READ: how to make ur tvtuner work with vista MCE
^^^ nice post man,but i think u sud hav posted this in the Tutorial Section.
hellgate is offline
Old 26-03-2008, 10:01 AM   #3 (permalink)
shadow hunter
ironically i visit only this section of thinkdigit
btw. if people find this thread useful then mods may please do the needful
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/83486-must-read-how-make-ur-tvtuner-work-vista-mce.html
Ab wann ist Cinergy HTC USB XS HD Vista Media Center kompatibel? - DIGITAL FERNSEHEN - Forum This thread Refback 30-09-2011 10:48 PM
Ab wann ist Cinergy HTC USB XS HD Vista Media Center kompatibel? - DIGITAL FERNSEHEN - Forum This thread Refback 22-06-2010 09:01 PM
how to make normal USB work with ps2 jaTT_puNJabi82 Peripherals 2 25-03-2008 01:48 PM
How to make this mobile to work ? Batistabomb Mobiles and Tablets 1 03-01-2008 01:14 PM
Well a little to make your computer work more fast krates Tutorials 7 06-11-2007 09:36 PM
Anarchy Online: How dyu make it work Muad'dib Gamerz 8 17-11-2005 02:13 PM
How to Tweak XP and make it work faster stalin Software Q&A 2 13-05-2005 06:21 PM
- by c4u
