Old 25-03-2008, 12:15 AM   #1 (permalink)
Default HELP :: Power Calibration Error
My DVD Writer was doing well and all of a sudden it denies to write DVDs.
I always keep backup of my important files in a DVDR Disc. But, I am getting a Power Calibration Error while trying to write DVDs. All the CD's are burning properly, only DVDs are giving that error.
This is not a DVD Write issue as I tried 3 different writer and when I connect my own writer to a different computer, it works fine.
Here is the error log I am getting..
Abhik is offline
Old 25-03-2008, 05:00 AM   #2 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Wink Re: HELP :: Power Calibration Error
Always search before you post. There are several threads on the same topic in this forum already. Although as you are a new member and it is your 1st post, I am posting the solution here.
Most probably you are getting this error because of the IMAPI CD BURNING COM SERVICE enabled on your PC. Just disable it and check if it works To disable it,
  1. on Desktop click Start
  2. select Control Panel
  3. click on Administrative Tools
  4. click on Services
  5. browse your way down to IMAPI CD BURNING COM SERVICE
  6. right click (on IMAPI) then select properties
  7. in the middle of the window, it will say start up type. Click on the arrow to the right and select disabled.
  8. make sure you click APPLY
If the procedure does not rectify the problem then your drive is faulty. Please take it to the service center.
debsuvra is offline
What is the Rectification for the Power Calibrating error Big-G QnA (read only) 1 08-01-2008 01:54 AM
power calibration error.....in cd drive vavinashraju Hardware Q&A 5 22-03-2007 02:37 PM
‘power calibration error’ ..... sandeep bhatia QnA (read only) 10 24-02-2007 09:50 PM
!!Power Calibration Error!! SUC*S Orionz Hardware Q&A 9 28-01-2007 11:26 AM
I get Power Calibration Fail hyde Hardware Q&A 2 24-08-2006 11:04 AM
- by c4u
