I just upgraded to a Intel DG33 motherboard with Realtek High Definition audio....I installed windows XP and installed the KB888111XPSP2 for detecting the audio device....Then i installed the driver provided in the mobo CD... But it says "Driver Installation Failure" and there is an exclamation mark on the high definition audio device..When i try to uninstall it it gIves an error "Uninstall Fail! The device is needed for the system to boot up"....What can be done 2 get the aound back....
